Cable question
1 Attachment(s)
Hi,
I just installed a new cable signal booster; and it is powered by a 12 volt adapter that hooks to rg cable. So I need to run a new cable to the nearest power source (about 35 feet.) It should be no problem since the booster says it can be up to 200 feet away. A while back I had taken what I thought was 500 feet of standard "cable tv" cable from a free item ad on craiglist. I never looked at it closely until today. The cable has 2 braided wires running thru it instead of one solid wire. It also looks a little thicker than standard RG cable. What is this cable? Can I use this cable for powering my new cable tv signal booster? I'm guessing not. How would I terminate it? I know how to terminate standard tv cable, but not this... What is this cable meant for? I've also been thinking about putting a large roof antennae up. Is this 2 wire cable made for antennae? How would someone wire it for this purpose? I've got so much of it, I'd like to put it to use. And while I'm asking, can anyone recommend a good value on a home roof antannae for HDTV. I am out in the country and want one that picks up distant channels. I don't care how big or ugly it is; but I don't want to spend too much. And would this antennae work with my 2 wire cable? Thanks! s |
HDTV and all TV signals require a digital signal now. So a roof antennae is no longer an option.
BTW I took a sample of that cable to my local Home store and none of the employees in the electrical dept knew what it was for. I bought some standard cable for my cable tv booster. I'd still be curious what that cable is good for if anyone knows. Thanks, s |
I've never seen a cable like that
There are still roof antennaes & you can pick up a signal, still an option It all depends upon station(s) near you if you will be able to get any signal I haven't used a roof antennae in a few years |
By researching on the net, I found it it's called twinax.
I'm still not sure what to use if for. Maybe I'll sell it on ebay... :no: |
Radio.
Twinax is a signal wire...used in many applications...usually transmitters. maybe something 2-way.
system is soon to switch to all digital signals. From what I am told, antennae only capture analog signals.
http://antennaweb.org/aw/welcome.aspx Some good reading for you. |
Over the air viewing is still available
http://www.fcc.gov/cgb/consumerfacts/digitaltv.html They aren't about to shut off TV to millions of people who do not have cable etc Quote:
must have read it from one of those lower level sites. I stand corrected, and I appreciate the corrections.
| All times are GMT -4. The time now is 08:53 AM. |
