To Bulkhead Or Not To Bulkhead? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 06-07-2013, 02:09 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,130
Before I put up the drywall, I'm pre-wiring the house with Cat6 (DIY HDMI) and coax.
I have about 8 coax cables going to my 'data central' spot under the stairs (it's about the most central point in the house).
So...would you install bulkhead fittings and have the cables nice and neat behind a panel or would you just run them straight to the respective device? (RF amp)
I'm pretty sure I know the answer....just want to make sure I'm not overlooking something.
ddawg16 is online now   Reply With Quote
Old 06-07-2013, 05:45 PM   #2
Rewards Points: 16
I install keystone jacks for both ethernet and catv outlets because it's neater and because I use solid conductor for permanent in-wall runs and stranded patch cables at the distribution patch panel/routers and at the devices. Also because I use 75ohm terminators at unused catv outlets.
DavidSeon is offline   Reply With Quote
Old 06-07-2013, 07:24 PM   #3
Rewards Points: 1,456
You'll find that MOST pros will run straight to the equipment rack, rather than use wall plates, which will make just one more junction that can cause issues.
This is especially true with HDMI distribution.
ktkelly is online now   Reply With Quote
Bulkhead Drainage Concern Enigma007x Landscaping & Lawn Care 2 09-04-2012 09:15 AM
Increasing height of Steel Bulkhead Concrete Foundation ulrichfolkers Concrete, Stone & Masonry 5 06-18-2012 10:40 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Bulkhead 295yards Drywall & Plaster 3 01-29-2011 11:27 AM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 10:24 AM
