-   Home Theater (http://www.diychatroom.com/f12/)
-   -   To Bulkhead Or Not To Bulkhead? (http://www.diychatroom.com/f12/bulkhead-not-bulkhead-181451/)
ddawg16 06-07-2013 01:09 PM
Before I put up the drywall, I'm pre-wiring the house with Cat6 (DIY HDMI) and coax.
I have about 8 coax cables going to my 'data central' spot under the stairs (it's about the most central point in the house).
So...would you install bulkhead fittings and have the cables nice and neat behind a panel or would you just run them straight to the respective device? (RF amp)
I'm pretty sure I know the answer....just want to make sure I'm not overlooking something.
DavidSeon 06-07-2013 04:45 PM
I install keystone jacks for both ethernet and catv outlets because it's neater and because I use solid conductor for permanent in-wall runs and stranded patch cables at the distribution patch panel/routers and at the devices. Also because I use 75ohm terminators at unused catv outlets.
ktkelly 06-07-2013 06:24 PM
You'll find that MOST pros will run straight to the equipment rack, rather than use wall plates, which will make just one more junction that can cause issues.
This is especially true with HDMI distribution.
