Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 10-29-2012, 10:13 AM   #1
Best Home Theatre Screen Choice
I was looking for some advice. I am living in Dallas and putting in a home theatre. The Home Theatre company I am working with wants to sell me an Elite brand screen. I trust them to a point; however, I assume they may have bias based on kick-backs they may get so I wanted to see if anyone had some "Un biased" input.
Here's my question:
Are most of the screen companies (SI, Da Lite, Vutec, Draper, etc..) using basically the same 3M coating for similar use screens? For example, I am looking for a screen in a home theatre room that will have almost no light. Therefore I am looking for a white screen (around 1.1-1.4 gain).
Does it really matter which brand I get due to the fact that with those parameters they are all going to be using the same coatings on the screen?
Thanks, any input would be appreciated!
scott t is offline   Reply With Quote
Old 10-30-2012, 12:41 AM   #2
They are more likely recommending Elite screens since that's a line they carry, not because of some kickback scheme. Kickbacks, spiffs, dealer rebates, etc, etc, are just not really things that happen in the industry like they once did.
Here's my question:
In answer to your question:
No, they all do not use "basically the same 3M coatings". Each company has their own method of construction in the screen make up.
I'd bet this company is using Elite Screens since they have a good working relationship with the company. They have a problem with some brand they don't normally sell, and it can be a very painful process. same problem arises with a company they deal with on a regular basis, and a problem becomes no problem.
Me? I dealt with Vutec when I was active in the business, and that's the company I always recommended. That was done for the reasons cited above, not for some hidden kickback scheme.
Hope that helps....
ktkelly is offline   Reply With Quote
Old 10-30-2012, 02:05 AM   #3
JOATMON
ddawg16's Avatar
Given the advances in flat panel displays, why not a LCD or Plasma display?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 11-02-2012, 02:28 PM   #4
For a nearly dark room, a plain flat white (gain about 1.0) screen will suffice. Even though each brand may have its own trademarked coating, the optical or performance differences between brands are very slight for this kind of screen surface.
You would not want an eggshell or other slightly shiny surface, that could cause hot spots.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 01-05-2013, 11:20 AM   #5
Go to the AVSForum for advice. You'll get a bit more transaction there.
But my advice would be Seymour AV screens.
Their Centerstage XD screens are very good for an acoustically transparent screen. I chose the upgraded Screen Excellence screen from Seymour because it is a 4K material so I should be set for the future. IIRC the Screen Excellence screen is about 2X the price of the XD material
LarryM is offline   Reply With Quote
Old 01-20-2013, 07:01 PM   #6
JPL
Stewart. Hands down the best.
JPL is offline   Reply With Quote
Old 03-11-2013, 11:02 PM   #7
Dave Sal's Avatar
You haven'tt experienced a real home theater until you've seen a 100" diagonal image.
Dave Sal is offline   Reply With Quote
Old 03-18-2013, 12:43 AM   #8
retfr8flyr's Avatar
I agree Stewart is hands down the best screen available. They cost more then other brands but there is a reason for that. I have had an 125 inch Stewart Ultimate 4-Way screen in my H/T for 12 years now and it has preformed flawlessly. I highly recommend them.
Earl
retfr8flyr is offline   Reply With Quote
Old 03-18-2013, 10:18 PM   #9
i have a Dalite high power 2.8, 119". simply fantastic screen !
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Tags
elite, home theatre, screen
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Oh! 1st home! Closing in two weeks! 30 Pics! Firefighter3244 General Discussion 24 05-19-2011 08:23 PM
NEWBIE- Looking to build my own Barn Home in Idaho LAWFISH General Discussion 2 11-14-2008 08:43 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
