7.1 Speaker location
The only way you are going to get an answer, is either meeting with a company that does a/v installs, or look through the multitude of information over at avsforum.com. The way I look at it, Left & right front flanking either side of the screen, Center Above tilted down, sub underneath, then your side speakers above the listening position, aprox 5-7 feet above the seat. More people are going with 9.1 & 11.1 systems. And really, you will not know how it sounds, until you get the room finished, and equipment installed and tweaked out.
But really, your answer can be found over at avsforum.com.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
