Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 03-01-2013, 05:18 PM   #1
2 Rim Joists on Sill plate with space between
I am running wires for my surround sound. I am trying to run wires through the basement under an exterior wall. There are two rim joist on that wall but there is gap between them. I am able to drill down into the gap from upstairs when I remove the molding on the floor. Has anyone ever dealt with this issue? Any advice on how to find where I am from the basement in order to find the hole I drilled from upstairs? I found a similar post but the rim joist did not have a space between them.
Running Wires From Basement Question
JasonPaul is offline   Reply With Quote
Old 03-02-2013, 12:26 PM   #2
SawdustBBB's Avatar
Just a thought, but possibly leave the drill in the hole and use a really strong magnet or a magnetic stud finder to locate the bit. With it being 1-1/2 inch thick wood that may be impossible. Another idea may be to drill another smaller hole from the bottom up thru the floor angled into the wall and push a coat hanger thru for reference. Measure off the coat hanger what ever distance is needed. Good luck.
SawdustBBB is offline   Reply With Quote
Old 03-02-2013, 03:57 PM   #3
Thank you. I was able to find the coat hanger pushed through a hole upstairs. I only had to make two holes near the wall and two in the rim joist. I had someone shake the coat hanger violently while I had my ear against the rim joist.
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 10:10 PM
Joists, Sill Plate, Foundation and broken main beam Bonebag Building & Construction 14 02-03-2013 08:40 PM
Sill plate hold down bolts jrepp44 Building & Construction 8 11-08-2012 10:20 PM
Replacing rotted sill plate in 120 yr old home M.dizzle Building & Construction 16 02-29-2012 03:53 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 06:28 PM
