Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Old 11-27-2012, 10:10 AM   #1
Wireless internet booster?
So I have a wireless Internet USB adapter to my PC but the problem is that my signal is very weak because of the distance it is from our router. Is there a way to make the signal stronger without moving the router closer? Some type of booster or anything?
Post-it is offline   Reply With Quote
Old 11-27-2012, 10:26 AM   #2
JOATMON
ddawg16's Avatar
Short of moving the router or getting a different one with more range, you can get a wireless repeater.
I installed one at my in-laws house. It works well.....you just have to understand how it works....it will actually show up as a different wireless access point....so instead of connection to 'my home', you would connect to 'my repeater'.....
BTW....how far are we talking?
If you have an old router...instead of buying a repeater...get a new one with more range....and while your at it...get one with NAS. Basically, NAS capability lets you plug a USB HD into the router and it is now accessable by any computer on your network. Sort of a cheap and easy way to have a network drive.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-27-2012, 10:57 AM   #3
SuperJETT's Avatar
If the antennas are removable from the router, buy new higher dbi antennas. They are cheap, no complicated setup, and work great.
SuperJETT is offline   Reply With Quote
Old 11-27-2012, 03:19 PM   #4
Well I am using a D-Link Xtreme N Dual Band N+300 USB Adapter. It's the first one I found that would actually even find a signal. My signal strength jumps up and down from 10% - 25%. The router and my computer are on opposite corners of about a 2500 sq. ft. house.
I did check the antennas and they are removable, so getting new antennas might help.
Old 11-27-2012, 03:31 PM   #5
JOATMON
ddawg16's Avatar
It's worth trying the antenna's...but I think you are only going to get marginal improvement. The freq is pretty high and chances are the installed antenna is already a full wavelength antenna....about the only improvement would be a remote antenna....and you can get the same result by just moving the router.
On your USB...is it the fixed type? Looks like a USB memory stick? If so....have you tried pluging it into a USB port on the other side of the computer?
I use a USB on one of my computers...but this one has a cord and the actual reciever can be mounted up high...
I still think your going to need a repeater....
My
and
Old 11-27-2012, 03:38 PM   #6
SuperJETT's Avatar
I use higher gain antennas at work for our office building which has concrete walls throughout. They work, they really do extend the range. 3 access points cover the entire building now where I used to have 5.
Old 11-27-2012, 03:54 PM   #7
Not to put too fine a point on it, but is this your house? Is running cat5 or moving the router THAT out of the question? Or are you just renting a room and stuck with what you have?
Adding a repeater is certainly your best bet given your restraints. It's going to add a bit of latency, so if you're a gamer, keep that in mind.
TheBobmanNH is offline   Reply With Quote
Old 11-27-2012, 04:56 PM   #8
Yeah you could say I'm renting a room and stuck with what I got. I'm not a gamer on the PC. I just use it mostly for surfing the web but would like it to be faster. We are in the 21st century and I need better than dial-up speed Internet, lol.
Old 11-27-2012, 05:00 PM   #9
JOATMON
ddawg16's Avatar
translation.....you live with your parents......and....the best way to save money to buy a house.
My
and
Old 11-27-2012, 05:51 PM   #10
Haha no. I rent a house with 4 others. I just can't relocate the router. I'm just looking for an affordable way to make it better because I may only be here for a few more months
Old 11-29-2012, 08:30 AM   #11
sdsester's Avatar
You might search Lifehacker. They often run feature articles on DIY built signal boosters. www.lifehacker.com
sdsester is offline   Reply With Quote
Old 11-29-2012, 08:34 AM   #12
sdsester's Avatar
Not sure where you are but is your own wireless connection in the budget? I have been delighted with CLEAR and get unlimited super fast service with no ceilings or throttle downs for $45/month. I had to buy my own modem thingie but it was cheap. Obviously I can take the connection with me.
CLEAR also sells a hotspot for $45 that you can tap with 6-8 devices.
I think Virgin has a plan for like $35 but it does threaten to slow you down after a certain data amount.
Old 11-29-2012, 09:16 AM   #13
Saw this "today only" 11/29/12, free shipping.
Diamond Multimedia WR300N Wireless-N Range Extender
http://mobile.dailysteals.com/
Don't know how well it works using house wiring.
Condition: New
Packaging: Retail
Warranty: 1 Year
Brand: Diamond Multimedia
Model: WR300N
Product Features:
• Can be used as a Wireless Range Extender, a Standalone Wireless Access Point, and a Wireless Bridge Device
• Receives weak wireless signals and extends the range to greater distances
• Eliminates wireless dead spots
• Easy to install
• Ethernet port
• Plugs directly into wall socket
• 300Mbps speed
• WEP and WPA security
• WPA2 encryption
• TKIP and AES algorithm
• 802.11b/g/n compatibility
What You Get:
• Diamond Multimedia Wireless Range Extender
• LAN Cable
• Installation CD
• Quick Start Guide
diyorpay is offline   Reply With Quote
Converting a wired to a wireless doorbell ohman Electrical 12 10-22-2012 11:20 AM
Extending or Modifying Wireless sensor for Tstat kilosos2 HVAC 4 04-15-2012 02:17 PM
How to make a Pc wireless polarzak PC Repairs & Upgrades 21 03-30-2012 01:50 AM
Booster pump experience nicuribe Plumbing 2 11-20-2009 06:16 PM
slow....................internet RichyL PC Repairs & Upgrades 16 10-20-2009 08:57 AM
