WiFi Getting Hacked? - Networking - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Old 11-08-2013, 08:13 AM   #16
First, from the manual of the router:
Page 70.
Wireless
Solid Green = WIFI is powered.
Flickering Green = Activity seen from devices connected via WIFI. The flickering of the light is synchronized to actual data traffic.
Off = The device is not powered or no powered devices connected to the associated ports
http://www.ron-berman.com/wp-content...g510manual.pdf
Second,
Turning off SSID broadcast and using MAC filtering provide a false sense of security? While I agree that it's not a particularly robust solution for the enterprise, running a Radius server in your home might be considered overkill, or in the very least, a bit outside the scope of ability for the average home user.
In my experience, most residential "hackers" are just looking for free internet. So in effect, you don't need to be the most secure wifi router on the block, you simply need to be more secure than "most" of your neighbors.
AJPLeBlanc is offline   Reply With Quote
Old 11-08-2013, 08:27 AM   #17
PoleCat's Avatar
Rewards Points: 1,646
My wifi is on at the moment but the light on the router is off. This is how it has been since installation except on those few occasions when I have found it on for some reason other than either of my wifi devices. The first time it happened I renamed the router and changed the rest of the defaults. The next time it happened I hide the SSID. The third time it happened I just turned it off for a day. When I turned it back on the light stayed off......for now anyway. So based on that history I presumed there was an unknown device connected that did not show up in the device list when ever this light was on. I thought that a connection needed to have my SSID and WEP key. We have never tried to connect either of our phones to the network. I don't think they are even "smart" phones to begin with.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-08-2013, 08:43 AM   #18
Mad Scientist
The only advice I could give is this:
Forget about hiding your SSID. It just makes it harder for some buggy wireless implementations to connect to your network, and it's still entirely possible to discover your networks SSID anyway.
Forget about MAC filtering, anyone can easily discover the MAC of a device that's allowed on the network, and set their device to use that MAC.
Enable WPA2 security with a strong passphrase. Unlike WEP, which can be cracked in a few minutes, WPA2 is really only vulnerable to brute-force attacks which try to guess the passphrase, which should take a very, very long time if your passphrase is reasonably strong.
Disable WPS, if applicable. Many routers these days have a "one-click connect" feature, often using a button you press on the router itself, or in the router's configuration. This feature lets a new device communicate with your router to set itself up and obtain the WPA key. There are some weaknesses in WPS that can allow someone to gain access to your network.
Once you've done all this, relax. You will be as secure as possible, unless you upset the NSA or something. Any occasional activity from your router's Wi-Fi light while your devices are powered off will only be due to one of a few things:
A device which is still in standby, maintaining it's connection to the network.
The router itself broadcasting occasional traffic and probing for devices
The router reacting to probe requests from neighboring devices and networks
Buggy firmware on the router (surprisingly likely)
McSteve is offline   Reply With Quote
The Following 4 Users Say Thank You to McSteve For This Useful Post:
djlandkpl (11-08-2013), gregzoll (11-08-2013), Nobr8ks (12-24-2015), RockyMtnBlue (10-08-2014)
Old 11-08-2013, 02:16 PM   #19
Rewards Points: 6,652
That confirms it, that the RG is using a Power saving mode, when it senses no wireless devices in its vicinity. I thought that they had done away with that "Green" feature on most consumer grade units, since it was causing more problems then saving power.
Do not get me wrong, that it was a nice feature on paper, when the engineers drew it up, but when it comes to real life use, it causes more problems with a lot of legacy equipment, that relies on that continuous Beacon the A/P sends out, for a "Keep Alive".
Old 12-06-2014, 03:03 PM   #20
Rewards Points: 225
sometimes turning off wps in the router software doesn't actually turn it off, unfortunately.
I'd still probably use mac address filtering to keep out the newbies. sure, someone determined to get access can easily spoof a mac address and get on, but I'd bet a fair amount of people do not know how to do that stuff.
andrewjs18 is offline   Reply With Quote
The Following User Says Thank You to andrewjs18 For This Useful Post:
Old 12-24-2015, 02:38 AM   #21
Rewards Points: 616
I'm definitely no computer expert but a few times I found my Wifi on when I had turned it specifically off. I thought it was the download updates doing it. I forget which one, I think I had three groups downloading updates. One specifically said it would do it even when I didn't agree to the schedule. I made all downloads only with my permission & the Wifi hasn't been on again without me. The camera has but that's another story :}
Nik333 is offline   Reply With Quote
Old 12-24-2015, 11:28 AM   #22
JOATMON
ddawg16's Avatar
Rewards Points: 1,470
I periodically look at the list of connected devices. My router will show me who is or has connected.
A few years ago I looked at it and saw about 20 unknown devices. Being the good neighbor I am, I shared the wireless PW with my neighbor on one side. On a particular football Sunday, she being the nice person she is shared the PW with all the guests. So 20 or so guests all had their smart phones on my wireless.
I turned on MAC filtering....allowed only devices in my house. A week later they had the cable company out installing internet.
ddawg16 is online now   Reply With Quote
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
dalepres (12-26-2015), Nobr8ks (12-24-2015)
Old 12-24-2015, 01:50 PM   #23
Use WFA2 and a pass phrase of 26 or more characters (random, not dictionary words). Disable WEP. You may see that light flash on occasion, it's maybe responding to anything including a joggers cell phone. So long as the device doesn't connect you are reasonable safe. Unless you are doing something with your on line time, no one is going really going to attempt to hack into your system via your wireless except to try and get free wifi. A secure wfa2 key should keep them out. Companies like Comcast have a second Channel on their cable modems that are public, that is anyone with a Comcast if can log in but they can not see your network
jimn01 is offline   Reply With Quote
Old 03-17-2016, 01:28 PM   #24
bradleyshome's Avatar
Rewards Points: 114
Re: WiFi getting hacked?
The router should have logs so log in and look at them if you don't see any devices that are not yours connecting then it should be all good
bradleyshome is offline   Reply With Quote
Honeywell redlink vs Honeywell wifi t-stats raylo32 HVAC 6 08-14-2013 07:13 PM
Looking for a wifi thermostat which also accepts remote sensors Upton O Good HVAC 7 06-02-2013 06:20 PM
Wifi Thermostat - Temp way above Target Temp sat324 HVAC 8 02-06-2013 09:17 AM
Converting cable Internet to WiFi?? polarzak PC Repairs & Upgrades 7 06-25-2012 08:49 PM
Is Leah crazy? Could my microwave kill my WiFi Leah Frances Electrical 10 02-29-2008 05:11 PM
