08-06-2010, 09:52 AM
#1
New House Newbie
Wierd NIC issue (both wired and wireless)
I have a friends laptop that can not connect to the internet. So I connect to their wireless network with good signal. Open up IE and cannot connect even though I am connected to the network. Try wired connection, same thing. Bring the laptop to my home network, same thing. I can ping itself, the gateway, and my server. I cannot ping google, it does not even come up and say pinging xxx.xxx.xxx.xxx with 32 bits of data when I try to ping outside the LAN. So I figured its a setting. I made sure all checkboxes with the proxy are unchecked. All IP's are obtained automatically.
Am I missing a setting somewhere? Or any other ideas?
P.S I am using my home network right now so internet access works
08-06-2010, 10:48 AM
#2
New House Newbie
I just realized that I cannot connect to any other machine on my network either. The laptop only sees itself on the workgroup.
08-06-2010, 10:55 AM
#3
First thing is see if your firewall is turned on. Go to your services in control panel > Admin Tools > Services and try shutting down the Windows Firewall and ICS service. Then try again. Google does allow you to ping your serves, but if you are not getting the message that you are attempting to ping an IP address, your DNS may not be able to look it up for some reason.
Try that, then report back.
08-06-2010, 11:01 AM
#4
are you getting a valid IP address?
169.xxx.xxx.xxx is not valid
Do an ipconfig /all from the command prompt and let me know what is displayed.
1. I would start by powering off the router for a few seconds
2. Check the NIC for a static IP. lots of companys set up static IPs on computers but not usually laptops.
3. Does this computer get on networks elsewere?
Like the above poster stated, the firewall may be blocking things. especially if it's a Symantec/Norton crap product.
08-06-2010, 11:10 AM
#5
New House Newbie
Alright, i stopped the firewall/ICS service and it still cannot hit the internet. Pinging all the same with the same results.
Wire NIC is disconnected
Wireless NIC
IP: 192.168.1.108 (it is DHCP)
Subnet Mask: 255.255.255.0
IP Adress: fe80::214:a5ff:fe69:da7a%7
Default Gateway: 192.168.1.1
DHCP Server: 192.168.1.1
DNS Servers: 216.16.0.2 and 216.16.0.4
Leased Obtained August 6th expring on August 7
Then it shows 2 tunnel adapter teredo tunneling pseudo-interfaces
-Not sure what these are
#6
This, do an ipconfig /all and copy and paste that here.
08-06-2010, 11:12 AM
#7
New House Newbie
I can't since I cannot get out the internet nor can I push the image across the network to another computer...unless I am missing an option?
It has Avast AV on it and I ran a full scan and found not threats.
08-06-2010, 11:14 AM
#8
to check DNS go to cmd and run: nslookup google.com
You should get a few timeouts, then a non-authoriative answer beginning with 209.85.xx.xx
What you transcribed earlier was good enough.
08-06-2010, 11:17 AM
#9
New House Newbie
Ran this and all timed out with error message saying "can't find server name for address 216.16.0.2" and the same for the 216.16.0.4 DNS
08-06-2010, 11:20 AM
#10
Ok, so your getting a valid IP from your router.
Open your internet explorer and select Tools/Internet Options/Connections TAB/LAN Settings button/ Make sure nothing is selected in there.
Was this computer ever on a Novell network?
Ok, bad DNS I see above
ipconfig /flushdns
ipconfig /registerdns
also did you unplug the router yet?
08-06-2010, 11:22 AM
#11
Try an ipconfig /release, then run ipconfig /renew and see if you pull any different DNS configs.
Go to your network properties and chose look at your TCP/IP properties for your wireless NIC, is the option check to pull DNS from the DHCP server? or is it set statically?
08-06-2010, 11:26 AM
#12
New House Newbie
Power cycled router, flushed and registered DNS without any errors. The computer I am using right now is using the same DNS obviously without any problems.
The IP and DNS are set to obtain automatically.
08-06-2010, 11:32 AM
#13
can you ping 192.168.1.1?
08-06-2010, 11:33 AM
#14
New House Newbie
Yes and also 1921.68.1.111 which is my server, but cannot navigate to them as the only computer the shows up in the workgroup is itself.
08-06-2010, 11:35 AM
#15
ok, I just saw that you have a server. does that handle all your DHCP and DNS?
is your server in a workgroup or domain?
is it a windows home server?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
