#1 |
Turn Router into Switch
I have a Linksys WRT610N that I would like to connect to my existing network as a switch but I'm not sure how to configure it.
The linksys has settings as follows: Internet Connection Type: (changed to static from auto) Internet IP : ? Subnet Mask (set 255.255.255.0) Default Gateway (network uses 192.168.1.254, not sure what to enter) DNS ? Network Settings IP address: ?(tried assigning 192.168.1.88) Subnet Mask: 255.255.255.0 DHCP Server (set to disabled) Any help appreciated |
#2 |
Wire Chewer
What you did should work, the key is disabling DHCP. And don't use the WAN port, just use the others, and you should be fine.
#3 |
The router is not accepting the settings I put in.
It says ip does not match gateway, tried a few different ways but it's not accepting the settings. |
#4 |
Turn Router into Switch |
| Display Modes | |
| No Heat: Pressure switch & Hoses forming traps | Yooperman906 | HVAC | 22 | 01-04-2011 10:52 AM |
| 1 pole + 3 way switch | momof2labs | Electrical | 1 | 05-22-2010 11:37 AM |
| 3-way light with a twist | Jeepsail | Electrical | 14 | 05-18-2010 02:24 AM |
| 3-way switch problems | bobbysan | Electrical | 6 | 05-02-2010 06:48 PM |
| Pressure Switch, Draft Inducer, Burner Box, Problem | majorapus | HVAC | 7 | 10-25-2009 07:14 PM |
