-   Networking (http://www.diychatroom.com/f11/)
-   -   Turn Router into Switch (http://www.diychatroom.com/f11/turn-router-into-switch-113473/)
RalphPeters 08-09-2011 09:37 AM
I have a Linksys WRT610N that I would like to connect to my existing network as a switch but I'm not sure how to configure it.
The linksys has settings as follows:
Internet Connection Type: (changed to static from auto)
Internet IP : ?
Subnet Mask (set 255.255.255.0)
Default Gateway (network uses 192.168.1.254, not sure what to enter)
DNS ?
Network Settings
IP address: ?(tried assigning 192.168.1.88)
Subnet Mask: 255.255.255.0
DHCP Server (set to disabled)
Any help appreciated
Red Squirrel 08-09-2011 11:50 AM
What you did should work, the key is disabling DHCP. And don't use the WAN port, just use the others, and you should be fine.
RalphPeters 08-09-2011 01:42 PM
The router is not accepting the settings I put in.
It says ip does not match gateway, tried a few different ways but it's not accepting the settings.
RalphPeters 08-09-2011 05:15 PM
Thanks, seems like I was changing settings that didn't need to be. Just had to disable DHCP server and that did the trick.
