RJ45 Coupler. - Networking - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Old 10-13-2015, 12:38 PM   #1
Rewards Points: 6
RJ45 coupler.
So i have an cat5e ethernet cable on the other end of my room. It is about 5-10 meters long. Can i use an RJ45 coupler to add another cable which is 5 M long to connect to my PC? Will a coupler slow down my network connection speed by A LOT?
sanzsmatic is offline   Reply With Quote
Old 10-13-2015, 01:35 PM   #2
The total length is well within the cat-5e specs. Every time you add a connection you have a potential loss issue and a potential to add noise. Not sure if the even make such a beast but it should be ok. I would just a new cable, but that is me
jimn01 is offline   Reply With Quote
Old 10-13-2015, 01:37 PM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
They do. They are intended for phone lines.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-13-2015, 01:47 PM   #4
Sippin' Tea
Sdyess's Avatar
Rewards Points: 110
It will not.
Sdyess is offline   Reply With Quote
Old 10-13-2015, 01:53 PM   #5
gregzoll's Avatar
Originally Posted by Sdyess View Post
It will not.
Will not do what? It is nothing more than doing the same with a patch panel. It works in those situations where you have to get someone up and going, until you can do a proper run. In this case, the OP will most likely not even notice any problems using it.
Old 10-13-2015, 01:54 PM   #6
Sippin' Tea
Sdyess's Avatar
Rewards Points: 110
I didn't even put the rest of my comment for some reason
I agree with you, It will not loose any speed.
The Following User Says Thank You to Sdyess For This Useful Post:
gregzoll (10-13-2015)
Old 10-13-2015, 02:06 PM   #7
Rewards Points: 6
Ok thanks people. Ill buy a coupler tomorrow. Hopefully no connection issues.
Old 10-13-2015, 08:17 PM   #8
Rewards Points: 1,094
Why not just buy a long cable.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
The Following User Says Thank You to digitalplumber For This Useful Post:
dalepres (12-26-2015)
Old 10-13-2015, 09:07 PM   #9
gregzoll's Avatar
I have been known to just grab some Cat-5e out of my odds and ends and put a Keystone on each end, if I do not have a coupler. Anything works in an emergency until you can get the stuff you need in your hands.
Old 10-14-2015, 06:11 AM   #10
Absolutely, but if he has to go buy the coupler......................
Old 10-14-2015, 06:13 AM   #11
Rewards Points: 6
I'd rather take a coupler than a longer cable. In my situation, it's more comfortable.that's as long as it doesn't slow down my connection speeds. I'm a gamer and the speed is important.
Old 10-14-2015, 09:22 AM   #12
gregzoll's Avatar
Depending on how good your computer is, along with your speed you are paying for. The Coupler is no different than using a patch pnel or a short run of cable with Keystones on the ends.
Old 12-26-2015, 01:13 PM   #13
Rewards Points: 297
Ok, I know this is an old thread but I just have to ask. A coupler is more comfortable how? Are you sitting on it and the coupler has less pokey things? I don't understand.
Because I would bet money that had you just bought a longer cable you wouldn't have had to come to a DIY forum to ask whether the longer cable would work so I don't know what else you might mean by more comfortable with a coupler.
dalepres is offline   Reply With Quote
The Following User Says Thank You to dalepres For This Useful Post:
digitalplumber (12-27-2015)
How to remove GE turntable coupler? HomeLearner Appliances 5 11-05-2014 09:53 PM
Cast iron to PVC coupler...Shielded or not? bobjax Plumbing 9 06-30-2014 05:14 PM
repair coupler Fix'n it Plumbing 6 02-24-2013 02:07 PM
flexible coupler benr Plumbing 7 06-13-2011 09:54 PM
PVC Slip coupler msaeger Plumbing 5 03-13-2011 09:46 PM
