Location Of Router - Networking - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > PC Repairs & Upgrades > Networking
Old 01-27-2008, 09:02 PM   #1
12 year IBEW member
location of router
I am looking at getting a dsl connection in my house and am wondering if it is pssible to put the dsl modem and wireless router away from my pc, I live in an older house so the phone wiring is not real current. and do not want to run a new line though the house. we currently have a lap top with a wireless n card and the pc has a pci adapter g in my pc. We currently share our neighbors dsl with their blessing but they are moving and we do not know the new neighbors yet.
could we just set up a station where the phone line comes in and manage there with the laptop, but then just use both wirelessly ( is that even a word?)
heavyduty is offline   Reply With Quote
Old 01-27-2008, 10:01 PM   #2
Residential Renovations
Tattoo's Avatar
You shouldn't have any problems with this setup.... most wireless routers have a lined connection and a wireless connection.
Tattoo is offline   Reply With Quote
Old 01-28-2008, 04:56 PM   #3
Rewards Points: 6,652
You can, but the signal can be wonky if you have Plaster walls, or the unit is placed in the basement. Depending on how old the Teleco wiring is in the home, it may work, but you will not know until you try. The best thing to do if you are able to, is place the Modem on a Dedicated Teleco line, and from there, run Cat-5e to various points in the house. Then you would be able to place the router at that point if not needing wireless, but if needing wireless, go with the 2-Wire modem if getting AT&T DSL.
Old 08-01-2008, 07:27 PM   #4
Ash
Send a message via MSN to Ash
Old phone wires are usually not a problem for DSL if they are connected ok. Expect it to work without problem
I join the ethernet cable recommendation. There are enough reasons to avoid wireless - from speed and reliability to health concerns
BTW : a 4 - pair 8 - wire etheret cable can connect 2 computers and not one. You can save alot of cable this way. Connect only the 1 2 3 6 wires of each netcard. I hope you dont mind your network to work at 10 mbit / s or 100 mbit / s half duplex
Ash is offline   Reply With Quote
Old 09-10-2008, 06:44 PM   #5
Router
The router needs one ethernet cable connection to a router for programing purposes.
After the router is programed, it must initialize and it drops wireless connections. (akin to sawing of a tree branch while standing out on the end.)
DSL fails from time to time and you will have to use the services of the ISP tech. he will be asking you the state of various lights etc., so you won't want to be running back and forth.
For this reason use a phone jack near your desktop then you'll be able to monitor the modem, router and computer conditions from one place.
Old 09-10-2008, 08:53 PM   #6
Electrical Contractor
kbsparky's Avatar
I cut a 14" square hole in the hallway wall, and put my modem and router in there. Bought a plumber's access panel cover to hide the hole, and then hung a picture over the whole mess.
Central location, gets good signal to anywhere in the house.
router irwinbuilt Carpentry 5 01-20-2008 07:22 AM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 01:26 PM
what size router bit for this job... KUIPORNG Remodeling 3 10-17-2007 02:00 PM
Drain location off by 1/4" jross Plumbing 24 03-30-2007 06:39 PM
Router Guide powrus Tools 2 05-02-2006 05:25 AM
