Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 12-26-2012, 02:04 PM   #1
yardmachine gold snowblower
Does it have shear pins? Engine runs fine, got a board stuck in it when blowing snow, now it won't blow snow. Any ideas on how to fix?????
buba36 is offline   Reply With Quote
Old 12-26-2012, 02:15 PM   #2
Just look in the manual, lost it then just Google the make and model. Lots of sites on line with have a parts break down.
Old 12-26-2012, 04:21 PM   #3
Yes, it should have a shear pin, usually a small clevis pin with a hairpin through it. As Joe said, find your manual, because some manufacturers anyway include an extra one or two pins in the same bag. Otherwise, your local lawn equipment dealer will most likely have them in stock. Buy an extra pair, and wire them to the handle.
The Following User Says Thank You to DexterII For This Useful Post:
joecaption (12-26-2012)
Old 01-29-2013, 02:40 PM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Not sure what model you have, but my Gold has a shear pin.
Did you check if the auger spins when you pull the handle?
CoconutPete is offline   Reply With Quote
Old 02-04-2013, 11:49 PM   #5
if you have a manual read it out if not goo to google type the model no. of tour machine and search it.
paulsmith544 is offline   Reply With Quote
Gold Desk MartiW General Discussion 4 10-11-2011 10:59 AM
Gas Jelly in snowblower - make it stop TechLauren Landscaping & Lawn Care 2 01-31-2011 05:53 PM
Using Gold Leaf on Door Hardware CaptChaos Remodeling 11 01-12-2011 02:38 PM
Snowblower Repair FF_Thor General Discussion 0 11-29-2010 04:51 PM
Toro SnowBlower 521 metallic sound mteach General Discussion 1 12-13-2007 01:27 PM
