-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   yardmachine gold snowblower (http://www.diychatroom.com/f106/yardmachine-gold-snowblower-167411/)
buba36 12-26-2012 02:04 PM
Does it have shear pins? Engine runs fine, got a board stuck in it when blowing snow, now it won't blow snow. Any ideas on how to fix?????
joecaption 12-26-2012 02:15 PM
Just look in the manual, lost it then just Google the make and model. Lots of sites on line with have a parts break down.
DexterII 12-26-2012 04:21 PM
Yes, it should have a shear pin, usually a small clevis pin with a hairpin through it. As Joe said, find your manual, because some manufacturers anyway include an extra one or two pins in the same bag. Otherwise, your local lawn equipment dealer will most likely have them in stock. Buy an extra pair, and wire them to the handle.
CoconutPete 01-29-2013 02:40 PM
Not sure what model you have, but my Gold has a shear pin.
Did you check if the auger spins when you pull the handle?
paulsmith544 02-04-2013 11:49 PM
if you have a manual read it out if not goo to google type the model no. of tour machine and search it.
