Troy Built Not Shutoff - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 03-20-2013, 06:24 AM   #1
troy built not shutoff
I have 8hp kohler with starter with dead battery it will start and stop via key,(starter rope). New battery will start but not shut off via key, have to pull plug wire. HELP???
William A is offline   Reply With Quote
Old 03-20-2013, 06:30 AM   #2
Rewards Points: 13,748
Please go back and read your post. Make any since to you?
What is it a mower, rototiller?
Model#?
Old 03-20-2013, 06:32 AM   #3
DIY staff
Rewards Points: 7,174
Fixed your title--
Did you touch the ignition wiring or by pass any of the safety shut offs?
That should shut off when you get up off the seat---------
Old 03-20-2013, 06:48 AM   #4
Its a 1985 troy-bilt horse rototiller w/8hp(6kw) kohler electric start (18ci) engine.
Old 03-20-2013, 06:49 AM   #5
oh Model # K181ST
Old 03-20-2013, 06:58 AM   #6
Have not touched any of the electronics this machine has been in storage over 15 years.
Old 03-20-2013, 07:04 AM   #7
Bad key.
Stuck starter solinoid or bendix.
Old 03-20-2013, 07:28 AM   #8
key is good.bendix is good. How can I test the solenoid
Old 03-20-2013, 07:35 AM   #9
http://www.buzzle.com/articles/how-t...-solenoid.html
It may not be attached to the starter in your case, but mounted some place else but the test is the same.
Old 03-20-2013, 02:21 PM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... The key should provide an Open circuit to the ignition, when "On", 'n should go to Ground, when "Off"...
Old 04-01-2013, 06:05 PM   #11
Rewards Points: 83
Check to see if the "kill" wire has been pulled loose or came off of the connection to the coil.
davido30093 is offline   Reply With Quote
Tags
norman
Built in BBQ and backyard remodel scotzilla Project Showcase 123 03-14-2014 10:15 AM
removing glass with blinds built in from one set of doors and installing them on a different set of doors. Al Polish Carpentry 4 05-21-2011 03:48 PM
House built in 1973 -- lead paint? 19mquinn79 Painting 6 04-12-2011 05:56 PM
pre built shower pans or custom built? vote4Pedro Building & Construction 6 04-07-2011 09:28 AM
Replacing countertop stove and built in oven becky3501 Carpentry 9 06-27-2008 08:41 PM
