Throttle Kit? - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-04-2014, 04:36 AM   #1
MarginallyQualified
Rewards Points: 2,464
throttle kit?
Does anyone know of a way to add a throttle control
to these newer pre-set walk behind mower engines?
(B&S Engine on Bolens here )
Old 04-15-2014, 09:49 PM   #2
A Little Of Everything
Rewards Points: 1,364
I'm sure you know that you can pick up such a kit at any farm & home store, etc. I've seen then recently for about $10.
If it were my mower, I'd pull off the covers and do some checking. There may or may not be a "throttle lever" that can be drilled and utilized for this purpose. It's really a crap-shoot.
Also, make sure you don't do this if the mower is still under warranty. Obviously...
DrHicks is offline   Reply With Quote
Old 04-15-2014, 10:39 PM   #3
Rewards Points: 6,652
Most are set at the factory and no way to adjust the carb throttle. Go to the local Farm & Home store with a small engine shop and talk to those guys. They can tell you if it is worth putting a throttle on the mower.
Old 04-16-2014, 08:44 AM   #4
Rewards Points: 14,306
Why would you want one?
A mower is suppose to be running wide open when cutting.
When would you need a lower speed?
Old 04-17-2014, 06:41 AM   #5
MarginallyQualified
If I did... why would I ask?
Who knows what evil lurks... (TheShadow)
Old 04-17-2014, 08:21 AM   #6
PoleCat's Avatar
Rewards Points: 1,652
Mine had the little lever peened down on top of the tank. Once that is free to move you can connect a cable to it.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Honda gx390 throttle stays wide open Dale Gribble Tractors & Mowers 1 09-04-2013 12:43 AM
Honda gx120 water pump throttle linkage aagill225 Building & Construction 0 06-15-2011 07:57 PM
Making Throttle body spacer disaresta Automotive Repairs 1 09-13-2010 11:43 AM
replacing throttle sensor on 2000 nissan altima bobo60 Automotive Repairs 1 05-21-2010 03:54 PM
BG55 Stihl Leaf blower limping along Yoyizit Landscaping & Lawn Care 5 01-14-2010 10:01 PM
