Tecumseh - Weak Spark - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-13-2014, 09:51 AM   #1
TJS
Tecumseh - Weak spark
Yardman shredder/chipper 8hp - "weak spark". I've replaced SS ignition, spark plug, cleaned and gapped magnet, kill switch OK - still very weak spark?????? HELP!
TJS is offline   Reply With Quote
Old 04-13-2014, 12:04 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
Did you check under the flywheel to see if the underside was rusty? Sometimes the pickup will corrode also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (04-13-2014)
Old 04-13-2014, 07:35 PM   #3
TJS
weak spark
Excuse my ignorance but what pickup? I did have the flywheel off but just to see how the magnet was attached.
Old 04-13-2014, 08:43 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
The pickup is a coil looking deal with two metal prongs that are very very close to the inside of the flywheel.
Jim
Old 04-14-2014, 02:36 PM   #5
TJS
Big Jim
You've got me stumped. . . I have a 8hp Tecumseh with SS ignition. I have a module (laminations) that is gapped .012" from the magnet on the flywheel. One wire from this module is a spark plug wire and the other is for the kill switch ( ground). I'm assuming this SS module contains circuitry to duplicate the points and condenser. With the new module and spark plug I still get a very weak spark???????
Old 04-30-2014, 11:37 PM   #6
Rewards Points: 332
Send a message via Yahoo to curtd
Are you turning the flywheel by hand or using the starter or pull rope ? Turning by hand was efficient for testing for spark when points and condenser were used, by now with SS ignition that method no now longer works.
curtd is offline   Reply With Quote
Old 05-01-2014, 07:17 AM   #7
Tom Struble's Avatar
Rewards Points: 2,002
sometimes a new module can be bad..i would also put in a new flywheel key while i had it apart
Tom Struble is offline   Reply With Quote
Old 05-01-2014, 08:51 AM   #8
TJS
try a new module?
When I got the module they said "NO RETURNS ON THESE UNITS" which either tells me "they wanted to do the work" , or "there have been problems with these modules" ?????
I have been testing by re-assembling and using the pull rope looking for spark at the plug!
Old 05-01-2014, 01:36 PM   #9
47_47's Avatar
Rewards Points: 58
There haven't been returns allowed for years on electrical parts. Would you buy one that has been returned? Are you sure you are grounding the plug to check for spark? I use one of these.
47_47 is offline   Reply With Quote
Old 05-01-2014, 01:49 PM   #10
TJS
weak spark
I use a jumper wire with a clip on the plug threads and on ground, I get an occasional spark but very weak. I have checked the flywheel key - It's good.
Old 05-01-2014, 11:54 PM   #11
Rewards Points: 332
Although extremely rare it does happen that the magnets strength has decreased. I hold a screw driver loosely about 1/4" away. It should pull it in. This method always worked for me
I soldered an alligator clip to a "test" spark plug to check for spark
Old 05-16-2014, 10:03 AM   #12
Central State Mower,LLC
Hello,
A couple of items can cause weak/erratic spark on a Tecumseh (or Briggs & Stratton) engine.
1. Re-check your coil-to-flywheel gap. Most small engines run well with a gap of .003-.007 A business card is very good for setting the proper gap.
2. Check the flywheel key. If the key is even slightly sheared, it can cause weak/erratic spark. Replace the flywheel key.
Hope this helps.
Mark P.
Central State Mower, LLC
CStateMower is offline   Reply With Quote
The Following User Says Thank You to CStateMower For This Useful Post:
DrHicks (05-16-2014)
Old 05-19-2014, 05:57 PM   #13
TJS
this issue resolved!
I finally solved the weak /erratic spark - I ended up taking it in to a shop and they replaced the "new" coil module.
Originally Posted by CStateMower View Post
Hello,
Hope this helps.
Mark P.
The Following User Says Thank You to TJS For This Useful Post:
BigJim (05-19-2014)
Weak spark - 8HP Tecumseh strod General DIY Discussions 7 08-11-2015 12:31 PM
Kenmore Gas Oven Won't Pre-Heat (weak btu output) zootjeff Appliances 2 07-15-2013 04:19 PM
Jenn-Air cooktop CVG2420W spark module replacement anku Appliances 3 03-28-2013 08:59 PM
2 cycle engine no spark walkinman Automotive Repairs 3 06-20-2011 10:12 PM
Lennox G23 furnace intermittent spark ignition carman HVAC 11 12-15-2010 05:41 AM
