Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 11-18-2012, 09:02 AM   #1
Snow Blower with gas left in tank
I have a very old Jacobson Snow Blower. Every winter I run it until the gas tank is empty before storing for the season.
Last winter I forgot. Will it help to add Sea Foam or Stabil now, before I use it for the season?
What should I do?
hubbard is offline   Reply With Quote
Old 11-18-2012, 09:14 AM   #2
Drain the tank before trying to start it and add fresh gas.
If you can find nonethenal gas always you that instead of reguler gas.
When's the last time the oil was changed?
Toward the end of the season this year add some Sta-bil to the fuel.
http://www.goldeagle.com/brands/stabil/
hubbard (11-20-2012)
Old 11-18-2012, 09:48 AM   #3
i just started my snow blower. it had gas in it from last winter. it started and ran just as it always has.
how much gas is in the tank now ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 11-19-2012, 11:54 PM   #4
About 1/2 tank. Do you think I could just add some new and give it a try?
Old 11-20-2012, 10:46 AM   #5
A Little Of Everything
What should I do?
Drain what you can out of the tank. Remove the carb bowl and clean it thoroughly. Spray carb cleaner up into/onto the exposed carb. Put fresh gas in. Give it a go.
Chances are you're going to be fine.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Old 11-20-2012, 08:33 PM   #6
in my experience, you have nothing to loose by trying it as is.
Old 11-22-2012, 11:13 AM   #7
so, did you try anything ?
Cheap Snow Blower - Snow Joe Slagwag General Discussion 15 12-08-2011 08:38 AM
Snow Blower under load Arnie 1345 Landscaping & Lawn Care 3 10-31-2011 09:51 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Snow Blower Repair Labrador General Discussion 5 06-03-2008 01:26 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
