Snow Blower Doesn't Start - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 02-13-2014, 12:20 PM   #1
Hi,
I'm having an Yard Machine MTD snow blower unfortunately it doesn't start...
I tried removing spark plug and put some starting fluid it starts for couple secs
and doesn't continue
can someone please help..
karsat is offline   Reply With Quote
Old 02-13-2014, 12:59 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,.... Sure sounds like the carb, or fuel lines are plugged up, seein's it starts briefly on ether,...
If it was runnin', 'n put away, Without drainin' the carb,...
I'd start with rebuildin' the carb,...
Old 02-13-2014, 01:17 PM   #3
yes it starts briefly for couple secs on ether...
Old 02-13-2014, 01:48 PM   #4
Rewards Points: 12,878
Remove carburetor, disassemble, and clean with carburetor cleaner.
Better yet while it's apart install a rebuilt kit.
Old 02-15-2014, 12:46 PM   #5
Rewards Points: 150
be careful with that ether, too much and you can punch a hole in the cylinder wall or piston. it should start with gasoline in the cylinder and might run a few seconds longer, but it definitely sounds like a carb problem. was It put away properly after the season? make sure you don't have any water in the gas tank or fuel bowl.
hpyjack2013 is offline   Reply With Quote
Reverse Gear, TroyBilt Snow Blower RCrosby257 Tractors & Mowers 6 12-30-2013 02:27 PM
5 HP 2 stage snow blower ? Fix'n it Tractors & Mowers 3 05-18-2013 08:47 AM
craftsman snow blower Harold L General DIY Discussions 9 03-03-2013 02:41 PM
Walk behind or lawn tractor with snow blower attachment bennett226 Landscaping & Lawn Care 6 06-04-2012 10:29 PM
snow blower will not hold a start bossmg2000 Landscaping & Lawn Care 4 01-28-2011 06:36 PM
