Sears Tractor
If my initial take was wrong, I apologize, but it sort of read like spam, so I was simply replying in kind. Happened to think though that, yes, they can be hard to move when not running, so perhaps you were serious. If it is a manual transmission, as Tarheel said, you can simply put it in neutral, and push it. If it is a hydrostatic transmission, and you are presently unable to push it, you will need to consult your owners manual for instructions to put the transmission in "freewheel" or similarly worded mode; this is typically a very easy thing to do, but because it is not a part of daily operation, is not typically and obviously labeled, and varies between manufacturer's, hence the reference to the manual.
