-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   Sears Tractor (http://www.diychatroom.com/f106/sears-tractor-139948/)
bjb37 04-11-2012 07:02 AM
Sears Tractor
Sears Tractor lawn mower will not start would like to roll it to shed is this possible Thanks Pat
DexterII 04-11-2012 07:09 AM
If it's your mower and your shed, I would say go for it.
TarheelTerp 04-11-2012 07:13 AM
have you tried to? put it neutral and push.
As to the starting issue...
DexterII 04-11-2012 08:43 AM
If my initial take was wrong, I apologize, but it sort of read like spam, so I was simply replying in kind. Happened to think though that, yes, they can be hard to move when not running, so perhaps you were serious. If it is a manual transmission, as Tarheel said, you can simply put it in neutral, and push it. If it is a hydrostatic transmission, and you are presently unable to push it, you will need to consult your owners manual for instructions to put the transmission in "freewheel" or similarly worded mode; this is typically a very easy thing to do, but because it is not a part of daily operation, is not typically and obviously labeled, and varies between manufacturer's, hence the reference to the manual.
DrHicks 04-11-2012 09:41 AM
Yes...
