Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-14-2012, 10:12 PM   #1
Ryobi Trimmer won't fully power up
I have a Ryobi trimmer 775R in which I have finally gotten to start but upon pulling on the throttle to increase the speed, the trimmer either stays the same speed or dies. Also, when I adjust the choke switch from A to B to C, when I move to C(or the run selection), it typcially dies but doesn't do die on B. Again, the speed will not increase.
Does anyone have any suggestions on what the problem might be? I have tried new gas, spark plug, new carb., cleaned out the muffler, checked the fuel filter, adjusted the carb settings. What else can I try? Thanks!
kennykenny is offline   Reply With Quote
Old 04-14-2012, 11:10 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Run some Seafoam through it. Depending on how long you have had it, the float could be varnished.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 04-15-2012, 10:22 AM   #3
Sorry, not familiar what seafoam is? Get at HD?
Old 04-15-2012, 10:58 AM   #4
MarginallyQualified
It's a magic elixir that every garage should have some of.
The others on that very short list are Sta-Bil, Techron, Marvel Mystery oil...
and PB Blaster. Get some of each today (at Wally's, AutoZone, etc).
http://www.seafoamsales.com/motor-treatment.html
Old 04-16-2012, 11:20 PM   #5
A Little Of Everything
I think you can get it at HD, but I'm not positive. Any auto parts store will have the stuff.
Regarding your question, there's about a 90% chance that you've got some old gas gumming up the main orifice in your carb. It's extremely common with oil-in-gas mixtures for 2-cycle engines.
The Seafoam should clean it out. If not, you may have to remove the carb and clean in manually.
DrHicks is offline   Reply With Quote
Old 04-16-2012, 11:39 PM   #6
Learning Things Every Day
Jay 78's Avatar
Electric!
I bought my electric Ryobi trimmer recently, and I will never go back to gas.
Now that I've said what I really wanted to say, here's something more on-topic: How's your fuel line? My dads suffered the same symptoms until he replaced the line. Might not be your problem, but you didn't mention it in your first post. Might be worth looking at to at least rule it out, if nothing else.
Under Construction
Jay 78 is offline   Reply With Quote
Old 08-11-2012, 03:28 PM   #7
I had the same problem, you have to put fuel stabilizer in the fuel, or take the piece of junk back where you bought it. Ryobi is the worst cusomer service I have ever delt with, very rude and cold. Try John Deere products, they work ten times better and their people are very nice.
Dpasqualic is offline   Reply With Quote
Old 08-11-2012, 03:38 PM   #8
sdsester's Avatar
Others will argue with me but I don't think ethanol was meant for small engines. You can get canned fuel without it pre-mixed with oil for two cycle engines. You should be able to find ethanol free gas at a marina too.
I don't like leaving two cylce fuel in things even for a short period of time.
Don't mean to insult you but I am sometimes known to forget the obvious. You did check the gap on the new spark plug right?
sdsester is online now   Reply With Quote
Old 08-11-2012, 03:42 PM   #9
sdsester's Avatar
Never mind. Just looked at the date of the OP. I suspect sometime over the course of 4 months the things was made to run or was replaced.
Old 08-12-2012, 09:51 PM   #10
I tried the Seafoam and didn't have an better luck getting the thing started. I didn't try the obvious with the spark plug gap but did try a new spark plug. I guess I assumed the gap was pre set at the factory. Maybe bad to assume?
Old 08-12-2012, 10:24 PM   #11
Yep. Almost never right out of the box....
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
sdsester (08-12-2012)
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 09:00 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
