Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-24-2012, 02:20 PM   #1
Removing spindle and shaft
I have to replace my shaft due to the star pattern stripping out on the bottom. My problems are that I can't just put the blade on and loosen the pulley nut because the star pattern is stripped. Also, I can't hold on to the pulley because my impact wrench broke the bolt loose a little then I stripped the threads on the pulley. What can I use to hold on to it so my impact wrench can do its job? Thanks.
tucker0104 is offline   Reply With Quote
Old 08-25-2012, 07:50 PM   #2
An old Tradesmen
Moved to tractors and mowers forum.
Old 08-26-2012, 08:36 AM   #3
A Little Of Everything
Please provide us with more specific information - make, model, etc.
Also, pictures would be VERY helpful. Thanks.
DrHicks is offline   Reply With Quote
bearing for drive/blade spindle mhern09 Landscaping & Lawn Care 1 06-28-2011 02:51 PM
