Removing Rear Tire On 1990 JD 170 - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-21-2012, 09:57 PM   #1
Removing rear tire on 1990 JD 170
Im am replacing disc brake pads and need to remove the right rear tire for easier access.
There are no bolts around the rim - just a small plastic cap in the center of the rim - there is a snap ring under the cap.
The rim extends 4 - 5 inches on the back side to the transaxle housing with no sign of a through bolt or key that I can see.
Just want to know what I am in for before starting what should be a simple R & R.
Thanks,
Pete
pbsmith is offline   Reply With Quote
Old 04-21-2012, 10:05 PM   #2
Rewards Points: 14,000
The rims on a spline if I remember right.
Remove the snap ring and just pull it off.
Sometimes there stuck and a few taps with a rubber hammer should get it loose.
Old 04-23-2012, 09:48 AM   #3
A Little Of Everything
Rewards Points: 1,364
Thanks,
Pete
The snap-ring is what holds the hub on the shaft. Remove it, and keep track of how the washers/bushings come off. The shaft will either be splined, or keyed. A 1990 model is most likely keyed.
You simply pull the hub off the shaft. Because of dirt and/or rust, it could be a bugger to get off. PB Blaster might become a good friend.
DrHicks is offline   Reply With Quote
Rear Tire Makes Clunking Noise dougp23 Automotive Repairs 9 05-02-2014 09:11 PM
Replace tire on a trade-in car? WillK Automotive Repairs 17 05-13-2012 12:41 PM
Tire dilemma- need help deciding noquacks Automotive Repairs 8 11-25-2011 12:36 PM
Dodge Dakota 2002 rear end rub ukrkoz Automotive Repairs 0 08-10-2011 02:42 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 05:12 PM
