Removing Clutch From My Craftsman Trimmer - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-15-2012, 11:14 PM   #1
Removing clutch from my Craftsman Trimmer
My 25cc 2 cycle power head for a convertible string trimmer has a bd clutch and I do not know how to remove it.
I have a new clutch but cannot remove the old one to replace.
Does anyone know how to remove the clutch?
timmygregory is offline   Reply With Quote
Old 07-16-2012, 07:56 AM   #2
A Little Of Everything
Rewards Points: 1,356
We need more information than this - specifically, brand and model number for starters.
Thanks.
DrHicks is offline   Reply With Quote
Old 07-16-2012, 09:28 AM   #3
Craftsman Trimmer power head clutch removal
Thanks for replying.
The brand is Sears Craftsman, model is the Model316711170.
It has speed start but I do not use.
I runs fine but the the head does not spin.
I removed the clutch cover and the clutch components fell out.
There is 2 1/4 circle plates and 2 springs holding them in the clutch housing.
I have another clutch (from another trimmer head) but I cannot remove the defective clutch.
The parts diagram does not show an screw or bolt that hold the clutch in place.
There is some give un and down but I don't want to break anything by forcing it.
I can email a picture of the assembly and the new clutch components if you want.
Thanks in advance for your help.
Alfred Gregory
Old 07-16-2012, 03:28 PM   #4
I'm going to take a semi-educated guess here, and say that the centrifugal drive part of the clutch is screwed on to the engine crank shaft. As you face it, it probably needs to be turned counter-clockwise to loosen and remove it. I do not know how you will keep the shaft from turning, while loosening the centrifugal clutch.
Good luck.
The Following User Says Thank You to DrHicks For This Useful Post:
timmygregory (07-16-2012)
Old 07-16-2012, 08:59 PM   #5
Thumbs up
Replacing clutch in Craftsman trimmer
I removed the clutch using a torx driver. A torx screw held the clutch main piece in place.
Doc Hicks said it might just twist off, and that got me checking for the screw. Since the torx screw was deep inside the clutch center, the screw was not readily visible.
I bought a set of the torx drivers and it ended up being a #8 torx driver that removed the screw. This allowed me to replace the clutch and now the trimmer works great.
Thanks for the help Doc.
Old 07-16-2012, 09:01 PM   #6
OooLaaLaa - I got lucky!
Are you back in business with the trimmer?
Old 07-16-2012, 09:27 PM   #7
Thumbs up
ATrimmer repair
Yes, the trimmer works perfect.
The springs in the old clutch were bad and stretched.
Thanks again!
Old 07-16-2012, 09:33 PM   #8
Thanks again!
Awesome - good job!
Removing blade from old Craftsman circular saw. Steve S Tools 22 03-30-2016 04:08 PM
How to remove the clutch from a craftsman trimmer head 25cc timmygregory Landscaping & Lawn Care 0 07-15-2012 09:28 PM
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
Removing a blade from an old Craftsman Circular Saw Davem720 Tools 1 07-05-2010 10:17 PM
Repair help w/ a cordless trimmer kennykenny Tools 6 06-28-2009 09:20 PM
