Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 03-24-2012, 12:11 PM   #1
Reel mowers...anyone have experience?
My yard is very small and mostly in shade. The grass doesn't grow that quickly and I'm thinking of buying a reel push mower. Any downsides to these? I've never tried one. The only issue I see is with sticks, acorns and such in the yard..it doesn't mulch.
DIYChick45 is offline   Reply With Quote
Old 03-24-2012, 12:15 PM   #2
A pain to sharpen, hard to push, jambs up if it picks up soild objects, good exercize though.
Old 03-24-2012, 03:54 PM   #3
Msradell's Avatar
They're nowhere as near as bad as Joecaptain leads you to believe. Many of the newer ones are very easy to push and actually all of them are if they are adjusted correctly. They're relatively expensive to get sharpened but if you take care of them this only needs to be done every four or five years. You will have to pick up any sticks before mowing or they could jam the mower and dull the blade. The only time they don't mow good is this you get tall spikes of grass which they have a hard time cutting.
Overall, for a small lawn that grows slowly they are ideal! Relatively inexpensive to purchase (although buying a good one isn't cheap), environmentally friendly and to get some exercise while mowing.
This is one of the best ones out there: http://www2.fiskars.com/Products/Yar...en/Reel-Mowers
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Ravenworks (03-24-2012)
Old 03-24-2012, 06:23 PM   #4
I had a powered reel mower, made in about the 50's. It cut beautifully, there is a reason that golf courses use reel mowers.
However, the issues are that it won't pick up the cuttings and any other detritus on the lawn. That's the main reason I went with a traditional mower is because it was nice to be able to vacuum the lawn of small sticks and pine cones and whatnot without having to go back over it with a rake later.
If you had a relatively small lawn, it wouldn't be much more work than using a gas mower to switch over. Plus it's better for the environment and the pocketbook.
Lyzic is offline   Reply With Quote
Old 03-24-2012, 10:04 PM   #5
Ravenworks's Avatar
Man you are bringing back memories,thats all my father ever used and nothing cuts like them either.
What Msradell is all true
Ravenworks is offline   Reply With Quote
Old 03-24-2012, 10:13 PM   #6
Ironlight's Avatar
The key is to cut often. If the grass gets too long then you're in trouble.
If you wheel the mower out to give the yard a trim on a regular basis, always before the grass gets too long for the reel mower to handle, it works great.
I used one for 10 years on a small lawn in a previous house and so long as I stayed on top of it, it worked great. And they are not that hard to sharpen yourself if you have the wherewithal.
I grew up mowing three acres of lawn with a walk behind, self-propelled, reel mower that was already ancient when my father got it from a neighbor for a bottle of whiskey. It was huge, red, ornery, and tempermental but boy was it fun when it was working well...as fun as powered mower can be, that is.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
Old 03-25-2012, 12:23 PM   #7
Check out the Fiskars reel mower....
It's not the same as those old evil things we grew up using as kids.
ktkelly is offline   Reply With Quote
Old 03-25-2012, 06:46 PM   #8
sdsester's Avatar
I think they are great for small yards. As mentioned, they do not work well with tall grass. You can still get baskets for the back of them if you want to collect clippings.
sdsester is offline   Reply With Quote
Lots of decorating experience, not so much of the repair experience sandrus Introductions 3 06-26-2011 10:40 PM
buying a new reel mower, any suggestions? shaner123 Landscaping & Lawn Care 0 02-26-2011 11:57 AM
Any experience with Roxul? Jim McClain Remodeling 5 02-23-2010 04:10 PM
Non-Gas powered mowers. Experience? Thoughts? IckesTheSane Landscaping & Lawn Care 3 12-03-2008 02:04 PM
Mounting Hose Reel on Stucco Siding xquercus General Discussion 5 07-03-2008 01:00 AM
