Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 02-17-2013, 03:43 PM   #1
primary and secondary belt removal
i have a 1972 john deer 110. i cannot figure out how to remove the primary and secondary drive belts for replacment. i looks like alot of doing to get them off, but hopefully there is a easy secret in doing this. could someome please help!
bkjwilly is offline   Reply With Quote
Old 02-17-2013, 03:49 PM   #2
Correct me if I'm wrong but the there's one belt that turns the blades and the other belt runs the hydrolics.
I own 2, John Deeres and used to own an L110 but there all newer then yours.
The easyest way is to remove the whole deck.
Old 02-17-2013, 04:06 PM   #3
there is no hydrolics. it's all manual or belt driven. i do have the deck off aready. i can't seem to find a way to loosen the belts in order to get them off.
Old 02-17-2013, 04:14 PM   #4
No idler to keep tention on the belt?
If you could post the model # I may be able to look up the parts list so I can see what your seeing.
There should be a sticker on it someplace with the model and serial #'s.
Old 02-17-2013, 04:20 PM   #5
i'm not sure about a model number, but the serial number is 250,001. hopefully that is enough to help you find what you need.
Old 02-17-2013, 04:27 PM   #6
Are there letters in front of the 110? Like LX, or L?
bkjwilly (02-18-2013)
Old 02-17-2013, 04:32 PM   #7
no. no letters in front of 110. just 110. 1972 tractor with a kohler k241 10hp engine.
Old 02-18-2013, 11:07 AM   #8
MarginallyQualified
This Service manual for the John Deere 110 Lawn and Garden Tractor. Also Known as the Patio Tractor, and is the gold standard reference for all "110" tractor repairs:
http://www.davenporttractor.com/p-11...en-sm2101.aspx
The Following User Says Thank You to TarheelTerp For This Useful Post:
Lennox Furnace - Primary or Secondary Limit Switch Open georgemeaders HVAC 4 12-12-2012 08:21 PM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-05-2012 12:07 AM
Central Air Secondary Drain Leaking - 3 questions walters_12 HVAC 7 05-11-2011 04:20 PM
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Boiler primary / secondary loop cruxop HVAC 3 08-13-2010 03:59 PM
