Pressure Washer Leaking Out - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-31-2012, 10:49 AM   #1
JPM
Bill Traver
Rewards Points: 99
Pressure washer leaking out
I have a TroyBuilt pressure washer from Lowe's...5-6 yrs old.
This year when I went to use it, I engaged the trigger but did not get lots of pressure. Ended up that water was coming out the opposite end of the aluminum housing from where the pressure wand hose is attached. The water is coming out of a black braid piece similiar to the white braid piece that is hooked up to my tank to syphon detergent mix for spraying.
When I took off the black piece, there was a brass piece with a white plastic part with what looked like a spring inside .. I think maybe it is stuck in an open position?
Anyway, can I just get a brass cap and close off this portal? I have no need to syphon anything else into the machine.
As always,,,,thanks!
JPM is offline   Reply With Quote
Old 07-31-2012, 11:41 AM   #2
Rewards Points: 13,444
Sounds like your talking about the pressure relief valve, if it is then no you can not just plug it.
Old 07-31-2012, 01:02 PM   #3
JPM
Bill Traver
Rewards Points: 99
After getting your note, I looked on-line for some pictures ... you are correct. Should have figured it out based on how the pump would surge at times then back off ... before finally getting the valve stuck open.
Thanks, going to the local Lawn & Garden Tool shop to pick up a new one and see what happens.
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Leaking Pressure Relief Valve of Boiler rob07030 Plumbing 2 11-02-2010 07:11 AM
pressure washer on well water Hardly Handy Plumbing 3 09-06-2010 08:16 PM
Has anyone ever used one of those garden hose pressure washer converter wands? jpearson311 Landscaping & Lawn Care 7 07-02-2010 05:05 PM
Honda 3540 pressure washer has no pressure Bulls Fan Tools 3 09-24-2009 01:36 AM
