Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-06-2012, 01:53 PM   #1
DIY Homeowner
Barry J's Avatar
pressure washer
I have a Craftsman pressure washer 6.75 HP 2500 PSI 2.2 GPM.
Last year the washer stopped working, I figured It was a little over heated but, this year I figured I would attempt to start it up to see what was wrong with it, but could not hook up the hi pressure hose to the aluminum outlet from the pump. There was a black plastic piece in the way.
On the diagragm from the owners manual it does not say anything about a black piece.
It looks like a vale of some sort, before I order another outlet and replace it, could this piece be from the pump and blown thru the outlet to the end???
I do have a pic of it but will attempt to attach it
Barry
Barry J is offline   Reply With Quote
Old 06-09-2012, 08:49 PM   #2
pressure washer
It does look like it may be from further upstream in the output side of the pump. It has been a while since I have had that type of pump apart so I am not sure. That tube should not have anything in it though. It is just an extension tube to get the discharge out to the edge of the washer body.
If you have the 9 digit sears number you can look up the washer & parts on their web site. There usually is some exploded views showing the parts inside. Most times I have to replace bad O-rings in washers when people run them dry
danpik is offline   Reply With Quote
Pressure washer blew the garden hose tucker0104 Tools 6 05-29-2012 07:51 PM
Looking for a motor capactitor for pressure washer andy1033 Electrical 0 10-07-2010 08:05 AM
pressure washer on well water Hardly Handy Plumbing 3 09-06-2010 09:16 PM
Pressure Washer Manifold Replace DIY JIM Tools 3 10-13-2009 08:50 PM
What to look for in a Pressure Washer ? Scott_K Tools 5 07-03-2005 02:43 PM
