Pressure Power Washer Help - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-05-2014, 05:16 PM   #1
Pressure Power Washer help
I was wondering if anyone has any experience with pressure washers on this forum. It is a Honda motor, Comet pump and Pulsar unloader valve. Im basically not getting any pressure out of the wand.
everyone is saying its the unloader valve, but I dont see what could possibly go wrong with it after I took it apart. The bottom of the valve contains a ball but no spring? Can anyone explain the operation of an unloader valve.
Im thinking it somewhere in the pump, but again I cant see what could go wrong? IM thinking I have a clog somwhere maybe but I dont know. Could I be losing pressure in the wand? There isnt any signifigant water leaks, just a drip here or there.
The washer was working fine last season. How could test the parts to see if theyre working correctly.
funkjosh is offline   Reply With Quote
Old 04-05-2014, 05:33 PM   #2
Oso954's Avatar
Rewards Points: 428
Have you pulled the water inlet screen and cleaned it ?
Usually it is located right were the garden hose is attached to the the unit.
A dirty screen will not provide adequate flow to the pump.
Oso954 is offline   Reply With Quote
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 07:32 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Has anyone ever used one of those garden hose pressure washer converter wands? jpearson311 Landscaping & Lawn Care 7 07-02-2010 06:05 PM
cleaning sewer lines with pressure washer ponch37300 Plumbing 3 07-06-2009 09:26 PM
excell pressure washer help ericsloan Tools 1 06-14-2008 03:39 PM
