Point Gap - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 02-17-2013, 11:08 AM   #1
point gap
how do i set the point gap on my 1972 10hp briggs? thanks.
bkjwilly is offline   Reply With Quote
Old 02-17-2013, 12:25 PM   #2
Rewards Points: 758
What model is the engine?
Normally, you'd set the gap at .020"
1. Rotate the crankshaft until the the points are wide open.
2. Insert your feeler gauge.
3. Loosen the bolt on the condenser and slide it until the gap is correct. You can use a screwdriver to move it if you have to.
4. Tighten up the bolt
5. Rotate the engine a few times and double check the gap.
Done.
If you are tired of dealing with points there is an "upgrade" available. It replaces the ignition coil.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
bkjwilly (02-17-2013)
Old 02-17-2013, 12:38 PM   #3
i was not thinking... it's not a briggs. it's a kohler K241. the points are mounted to the outside of the engine. is an upgrade available for this engine as well?
Old 02-17-2013, 12:58 PM   #4
Rewards Points: 758
That changes things a bit. No worries
The gap is still .020.
1. Take off the cover and disconnect the spark plug. Rote the engine until the points open their widest.
2. Check the gap. To adjust, loosen the top screw and move the base of the points with a screwdriver blade until the gap is correct.
3. Tighten all the screws and replace the cover.
To verify timing:
You'll find a "timing sight" hole in the blower housing or the bearing plate. It might have a cover - remove it.
Turn the engine over - the way it usually rotates, you should see either an S or SP mark (with compression release) or a T (without). The points should just begin to open then. If it opens early, narrow the gap a little, to .018. If it opens late, widen the gap to .022.
There are upgrades. Try this site: http://www.kirkengines.com/
Old 02-17-2013, 01:13 PM   #5
Wink
i will give this a try. i wont be doing this for about another few months though. it's still snowing and blowing here in Pa. i'll let you know how things turn out. thanks for your help, and the link you posted.
Uneven floor and joists in new room Orangeclawhamme Building & Construction 35 11-16-2011 10:57 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 09:30 PM
carrying drywall from point A to point B - Panel Carry Handle? panel handler? newbpainter Drywall & Plaster 9 04-24-2009 12:01 PM
Shallow point wells Dean1234 Plumbing 2 04-21-2009 10:21 PM
Point of Entry Surge Suppression Question eltrigo Electrical 1 06-02-2005 06:14 PM
