-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   New Generator wont start (http://www.diychatroom.com/f106/new-generator-wont-start-176515/)
P Marage 04-07-2013 06:26 PM
I bought a little generator for camping(2 stroke, 40:1 mix), it has maybe 20 hours run time on it.
Last summer I was using it, it was running like a charm until my brother suggested that when I shout it down, I should just turn the gas line off and let the motor run out on its own instead of just shutting it off and turning the gas line off. He says thats how they do it at work.
Later that day I tried firing it up again but it would not start.
I pulled the spark plug off and poured a little gas into the chamber, it fires right up for about 5 seconds so I know the motor & and plug is fine. Repeated this 7-10 times then gave up.
Spring is upon us again so I should figure this out before camping season starts.
Any ideas why the fuel is not going to the motor?
Thanx for any advice in advance
joecaption 04-08-2013 09:32 AM
Did you open up the valve to allow the gas to flow?
Did you dump out the old gas before trying to start it?
Have you removed the bowl on the bottom of the carberator and lifted up the float bowl to see if the gas starts and stops?
Most of the times the carb. is trashed up if your using gas with ethenal in it.
biggles 06-23-2013 06:22 AM
low oil cutoff? check manual
digitalplumber 06-24-2013 09:03 PM
Don't shut it down like that! I did that and had to get a new head from the vendor. It wore an oblong hole in the aluminum head.
