Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 11-18-2012, 05:45 PM   #1
My Cub Cadet LTX 1045 wont start
Thought it was just a dead battery. Replaced and installed a new one. The engine now cranks (where i had no power before) but it still wont turn over. I went ahead and removed old fuel from the tank. Cleaned out the tank and put in new fuel. Still cranks but still not turning over. The tractor is only about a year and a half old. Ive reached my scope of knowledge in trouble shooting it and hope it is still an easy fix.
41Souls is offline   Reply With Quote
Old 11-18-2012, 09:45 PM   #2
Did you try a shot of starter fluid into the carb while cranking it?
If that doesn't get it to fire at least a bit, then, at least for me, it tells me that the mice have chewed through the wires again!
cgoll is offline   Reply With Quote
Old 11-19-2012, 07:04 AM   #3
Not sure I understand cranks but won't turn over. If it is turning over but just won't start and it has sat for a while it could be the ethanol in the carb has gummed up. Thats what happened to mine, had to have the carb cleaned. A buddy who has a boat repair business told me his business has increased around $10,000 a year since they started put ethanol in gas. Thank you Washington.
Old 11-19-2012, 08:13 AM   #4
Need to clear that up. Is the engine turning over but just will not start, or is it just not doing anything when you turn the key?
If it's not doing anything then most often it's on of the safety switchs.
Double check the blade is shut off, it's in nutral, the clutch (if it has one) is engaged, someones sitting on the seat.
ToolSeeker (11-19-2012)
compressor wants to start but won't wetbar HVAC 13 06-17-2010 07:15 PM
Homelite weedeater won't start. Out of ideas. Jasnall Landscaping & Lawn Care 7 06-03-2010 02:12 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 09:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 11:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
