Mower Not Getting Gas - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 03-26-2016, 09:13 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 114
Mower not getting gas
I have a push mower that will run as long as you pour gas in the carburetor. I have cleaned out the tank and the screen on the pickup tube is clean. It just won't draw gas out of the tank. I left it at a shop once and they supposedly fixed it. First time I tried to start it, it was doing the same thing as before. Pour gas in the carb and it runs till it burns it all. I don't need it, but it bugs me tht it won't run.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-26-2016, 09:31 PM   #2
Rewards Points: 6,652
What if you take the tubing off and blow in it? Some tanks have a filter inside of them.
Also the Primer bulb only needs a small crack in it to pull air to keep it from getting a vacuum. Same as the primer bulb lines.
Old 03-27-2016, 05:33 AM   #3
Rewards Points: 104
Re: Mower not getting gas
Try it with the gas cap loose, just enough to prevent it from sloshing gas out when it runs. The cap has to vent in order for it to draw fuel, so clean or replace it if that helps. If not, I would replace the fuel lines, or at least check them, as Greg mentioned. After that, it's most likely the carburetor. Some carburetors cost little enough that it makes as much sense to replace as to rebuild.
The Following User Says Thank You to DexterII For This Useful Post:
dd57chevy (03-28-2016)
Old 03-27-2016, 07:10 AM   #4
Rewards Points: 106
the carb is dirty, it needs tobe taken apart and cleaned out, probaly dirt caught in the needle and seat valve..
goobertime is offline   Reply With Quote
The Following 2 Users Say Thank You to goobertime For This Useful Post:
joecaption (03-27-2016), oh'mike (03-27-2016)
Old 03-27-2016, 08:43 AM   #5
Rewards Points: 236
perhaps a bad float
Fix'n it is offline   Reply With Quote
Old 03-27-2016, 08:56 AM   #6
Rewards Points: 1,250
Very true, and another convenience invention that causes problems.
If the float isn't floating or the needle / seat function is defective the engine will be flooded with gas rather than deprived of gas.
Old 03-27-2016, 09:30 AM   #7
Rewards Points: 106
maybe you missed the part that the mower runs if gas is poured down the carburetor????
The Following User Says Thank You to goobertime For This Useful Post:
gregzoll (03-28-2016)
Old 03-27-2016, 02:02 PM   #8
Rewards Points: 114
And it runs good until it burns what i poured in.
Old 03-27-2016, 02:31 PM   #9
And I suspect you missed the part by Greg that stated a vacuum is needed to draw gas from the jet in the carburetor to the combustion chamber not air entering through a cracked line or primer bulb. Hell, I can run an engine without a carburetor by pouring gas in the intake manifold.
Old 03-27-2016, 03:05 PM   #10
Rewards Points: 106
again your comment on the carb being flooded is false if it runs by pouring more fuel down the carb..
Old 03-27-2016, 04:58 PM   #11
One thing is for certain, I'll not be bringing a mower to you. I'll take it to someone that can read with comprehension.
Old 03-28-2016, 07:55 AM   #12
dd57chevy's Avatar
Rewards Points: 830
Um , Dexter made a good point . If the gas cap is sealing tight , it can create a vacuum .
dd57chevy is online now   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
HELP!!! Dixon 4423, 2001 ZTR mower geoffb Landscaping & Lawn Care 4 08-13-2012 01:01 PM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 09:29 AM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 12:43 PM
