Machine Repair - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-26-2013, 02:27 PM   #1
Question
Machine repair
Honda rider mower model ht-r 3009 will not shift into neutral although shift lever goes into neutrol postion. This machine is an older model manufactured in 1985. Need expert advice.....before i tear into it a little too far.
Joncon
JONCON is offline   Reply With Quote
Old 06-29-2013, 10:31 AM   #2
Too Short? Cut it Again!
Check the shift coverplate to make sure it has not slided on you. Check any linkage.
I assume from your post the mower still engages when you put in gear to go forward?
The Following User Says Thank You to user1007 For This Useful Post:
JONCON (06-29-2013)
Old 06-29-2013, 12:38 PM   #3
Will check it out. Thank you !
Old 07-02-2013, 10:47 AM   #4
Roofmaster
Rewards Points: 2,172
Find a parts breakdown and try to glean the theory behind the drive. From there, you can figure out the problem.
foundation Repair Questions njhammerman Building & Construction 8 02-13-2014 08:18 AM
Req opinions on professionally completed drain repair. Mig3 Plumbing 8 05-19-2013 01:53 PM
Dryer repair DIY gone wrong... partly... jca2010 Appliances 6 09-24-2012 10:22 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
LG Front loader washing machine repair sharz Appliances 1 04-19-2008 11:30 PM
