-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   Machine repair (http://www.diychatroom.com/f106/machine-repair-182538/)
JONCON 06-26-2013 01:27 PM
Machine repair
Honda rider mower model ht-r 3009 will not shift into neutral although shift lever goes into neutrol postion. This machine is an older model manufactured in 1985. Need expert advice.....before i tear into it a little too far.
Joncon
user1007 06-29-2013 09:31 AM
Check the shift coverplate to make sure it has not slided on you. Check any linkage.
I assume from your post the mower still engages when you put in gear to go forward?
JONCON 06-29-2013 11:38 AM
Will check it out. Thank you !
jagans 07-02-2013 09:47 AM
Find a parts breakdown and try to glean the theory behind the drive. From there, you can figure out the problem.
