Looking To Buy A Used Walk Behind Blower - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-18-2016, 01:48 PM   #1
Rewards Points: 155
Looking to buy a used walk behind blower
was hoping some of you seasoned pros could give me some tips as to what to look out for when buying used small engine power tools.
any input would be greatly appreciated.
rygar is offline   Reply With Quote
Old 08-18-2016, 02:52 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,696
Re: Looking to buy a used walk behind blower
Do we assume snow blower? If so, much will depend on where you are (snow volume), size of area to blow, etc.
lenaitch is offline   Reply With Quote
Old 08-18-2016, 05:59 PM   #3
Rewards Points: 13,712
Leaf blower, snow blower?
Buying any power tool with no hour meter is going to be a gamble.
If your talking about a wheeled blower mostly used for blowing off driveways and a home owner owned it, there likely selling it because they almost never used it and when they did it was hard to start because it never got used.
First things I do is smell the gas tank, smells funky and not like fresh gas, you can plan on replaceing or rebuilding the carb. and fuel lines, filter if there is one.
rygar (08-18-2016)
Old 08-18-2016, 07:39 PM   #4
Next thing is to look over the overall condition, rust, wheel condition, does it start in a couple of pulls, no smoke when running, does it need the choke set 1/2 way to run?
As my general rule I check out what a new one cost and only pay 40% of what a new one would cost if it's in good shape.
I also Google the model # and add complaints.
rygar (08-18-2016)
Old 08-18-2016, 10:26 PM   #5
Rewards Points: 155
sorry gents, leaf blower
Old 08-19-2016, 11:04 AM   #6
A Little Of Everything
Rewards Points: 1,364
If you're going to buy a gas-powered leaf blower, just go with one of the lesser expensive ones.
THE SINGLE MOST IMPORTANT THING IS TO RUN THE RIGHT GAS/OIL MIXTURE. THAT IS MORE IMPORTANT THAN ANYTHING ELSE.
You can buy a really expensive one, but those are actually built for commercial applications. As a homeowner, you'll probably never wear out a cheaper blower.
DrHicks is offline   Reply With Quote
Lenox furnace exhaust blower motor replace tmtater HVAC 5 03-05-2014 04:45 PM
Blower not running - Package unit, A/C & Gas Heat justplumducky HVAC 4 09-22-2013 07:13 PM
Carrier - Blower fan NOT coming on anku HVAC 8 08-30-2013 08:46 AM
Blower won't stop after replacement of ignition control module jhevelone HVAC 2 02-17-2013 05:11 PM
Water heater blower needs re-wire kittf Plumbing 7 12-18-2010 10:44 PM
