Lawn Tractor Service Ramp? - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 05-09-2012, 06:25 AM   #1
"Old" Newbie
Rewards Points: 177
I have a lawn tractor with mower deck that needs frequent cleaning to remove matted grass from the under side. It's a 42 inch, 3 blade deck and reaching under to scrape away the buildup (ignition off, plug wires pulled!) is a hassle. I've considered a block and tackle hung from a maple tree to lift the front, building ramps (but if I do I'd like something easy to store out of the way, perhaps collapsable), and just running it so long as the blades will turn. Any suggestions? Words of advice? Plans or systems?
Any and all greatly appreciated.
Thanks,
Rob
RCrosby257 is offline   Reply With Quote
Old 05-09-2012, 07:46 AM   #2
I had one just like it and it was a pain. I used 2 methods when a foot or so was enough I used 4 drive on car ramps. When I needed more I used 2 of those long ramps used to load RTV into a truck and put them on the edge of my porch and drove the mower part way up. I was using a pressure washer to get the stuff out it was so bad.
My final solution was not to ever buy a mower with a deck like that again. These normally are the ones they sell as high lift or mulching decks. They suck up lots of dirt and mix it with the wet grass and you get almost concrete. It did help to buy blades that were more flat so they did not suck up so much dirt.
My current mower has a shallow deck and it never builds up even if I cut grass as high as the mower.
bill01 is offline   Reply With Quote
Old 05-09-2012, 08:30 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I saw one of these at my local Tractor Supply yesterday
http://www.tractorsupply.com/mojack-...r-lift-1023598
tcleve4911 is offline   Reply With Quote
Old 05-09-2012, 09:24 AM   #4
Rewards Points: 3,130
Yes, Tractor Supply has a number of different ones.
Old 05-09-2012, 12:05 PM   #5
"Old" Newbie
Rewards Points: 177
Cleaning the Deck
Thanks for the advice guys! I'll try a set of flatter blades; hadn't thought of that, and will certainly keep shallow deck advice in mind when it comes time to replace. You're right, it was designed for a mulching insert, which I took out years ago. It now stands as a lawn ornament in my wife's garden!
In the mean time I'll just use a couple of 2X8 planks against the porch!
Old 05-10-2012, 10:51 AM   #6
slide a sprinkler under the deck and water it
Eric_H_E is offline   Reply With Quote
Old 05-11-2012, 01:05 PM   #7
I have a chain fall hung from a beam. I stand the mower up practically on its nose. Just need to watch it doesn't start leaking oil or gas. After I clean it thoroughly, I shoot the whole deck with a silicone spray or whatever it is I have handy. I don't know how much good it does but it seemed like the thing to do at the time.
Oh, and I give the oil 5 or 10 minutes to settle back down before I start it.
And there is always the other option. Remove the deck to clean it.
2much2mow is offline   Reply With Quote
What the hell happened to my lawn? (also: reseeding when weeds are present. N.Y.) Deck Landscaping & Lawn Care 14 05-24-2011 12:45 PM
Lawn Help garydigital Landscaping & Lawn Care 4 03-06-2011 03:36 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 12:34 PM
Wheel Chair Ramp to Curved Step PaliBob Project Showcase 0 10-27-2009 04:35 AM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 11:36 AM
