Lawn Tractor Has No Power - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-06-2012, 05:57 PM   #1
Hi everyone,
I have a John Deere L130 lawn tractor. It has been losing power about a 1/2 hour into the grass cutting. It's fine when we start but about a half hour into it, it will not climb small inclines. I put the throttle all the way down and it doesn't move. It sounds like when your car is low on power steering fluid and you turn the steering wheel all the way to one direction. Is this a belt, spark plug, bad gas, fuel filter.....? I'm not very mechanically inclined. Please help.. Thanks!
Smoke is offline   Reply With Quote
Old 04-06-2012, 06:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,.... Load it up, 'n bring it to yer local service center....
Does the motor rev, 'n ya go nowhere, or does the motor die out,..??
Is there oil in the motor,..??
Does it Smell when loosin' power,..?? if so, like What,..??
Old 04-06-2012, 07:04 PM   #3
Motor runs fine....doesn't die out...there'es oil in it....No smell.....
Old 04-07-2012, 07:37 AM   #4
Framing Contractor
Rewards Points: 98
Maybe the coil? Years ago, mine would start fine, then start to sputter and die about 20 minutes later.
sixeightten is offline   Reply With Quote
Old 04-07-2012, 09:40 AM   #5
Rewards Points: 768
could be the battery too. How old is the machine?
cibula11 is offline   Reply With Quote
Old 04-07-2012, 09:53 AM   #6
A Little Of Everything
Rewards Points: 1,362
Originally Posted by Smoke View Post
Hi everyone,
That sounds more like your hydrostat than your engine. It could be low on oil, or it could be that the belt that runs the hydrostat is needing to be replaced. Worst case scenario is that the hydrostat is "going out" - which would result in a repair bill that's higher than the value of the machine.
(I have an L120 John Deere, by the way...)
DrHicks is offline   Reply With Quote
Old 04-07-2012, 12:26 PM   #7
Is the hydrostat belt different from the main mower belt? How do I check it if it is?
Old 04-07-2012, 12:36 PM   #8
Rewards Points: 12,856
http://www.justanswer.com/sip/john-d...&JPCD=20110527
There's two drive belts one for the deck and one for the hydo on a L110.
Old 04-07-2012, 12:41 PM   #9
Yes, it's a different belt. The pulley that drives the hydrostat belt is about 4" closer to the engine than the pulley that drives the deck. It's a thinner belt.
You can see it by looking over the rear wheels, at an angle, down and into the frame. It's hard to describe, but when you see it you'll get it.
Look over the belt carefully. Is it cracked and/or brittle? Reach in and pull on it to see what kind of tension it has. Make sure your "brake" is off, or you'll have NO tension on the belt.
Replacing the belt is going to be a pain in the butt, requiring removal of the deck. But it can be done.
Good luck!
Old 04-07-2012, 12:48 PM   #10
One good thing is on a L110 removing the deck is about a 5 min. job with no tools needed. I remove all the clips washers and brackets, slip the belt off the drive pully and slide the whole deck out from under it.
I set two concrete blocks on the ground and set up some ramps and drive the tractor up the ramps, or you can use ramps you use for changing the oil in your car. Block the back wheels, set the brake for safety.
Old 04-07-2012, 12:52 PM   #11
The L110 has the 42" 2-blade deck, right? Does that leave a nice smooth cut, or are the blades big enough that it's a little patchy?
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 09:00 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
