Lawn Mower Starting Issue - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-06-2014, 05:02 PM   #1
Rewards Points: 12
Lawn mower starting issue
I have a craftsman push mower with a briggs engine. The only way I can start the mower is if I prime a few times then I have to tilt the mower about half way on it's side then if I pull it will start in one or two pulls. If I do not tilt with I can pull and pull and it will never start. Any ideas on what I can check to try and fix this issue so I can start normally. I have even tried priming a few extra times and that does not help.
syoung3765 is offline   Reply With Quote
Old 07-24-2014, 11:57 AM   #2
Rewards Points: 332
Send a message via Yahoo to curtd
Off hand i would say the primer is not working. To check, remove the air filter, press the primer. You should see gas shooting into carburetor
curtd is offline   Reply With Quote
Old 07-24-2014, 12:16 PM   #3
Rewards Points: 13,732
Very common for the primmer bulb to get a crack in it, most are easy to replace by just removing 4, small screws.
New Homeowner - Lawn Mower Advice 7 VII 7 Landscaping & Lawn Care 20 04-26-2013 11:21 AM
Electric Lawn Mower Purchase Decision jasonnewyork Landscaping & Lawn Care 5 03-28-2011 06:22 AM
lawn mower small engine...struggling joetab24 Automotive Repairs 1 05-05-2010 08:00 PM
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 01:34 PM
lawn mower problems jamesw6777 Tools 9 08-04-2008 01:22 PM
