03-12-2013, 08:02 PM
#1
Lawn Mower can't start
I have a Yard Machines (by MTD), not used for a while but now it can't start.
I replace the spark plug, air filter and still not solve the problem.
5.5 HP, 21 inch cut
MTD model: 11A-416Q729.
It worked fine before and just long time not using.
What's wrong with it?
Anybody knows? Please help.
Reason: typo
03-12-2013, 08:31 PM
#2
Super Moderator
I moved this to 'small engines /tractors"---Mike----
03-12-2013, 08:34 PM
#3
Super Moderator
Are you getting spark? Sometimes rust on the flywheel will cause the magnito to malfunction.
That's a bit of work to fix--so see if the spark plug wire is getting juice---
03-12-2013, 09:19 PM
#4
Need a whole lot more info.
Start from turning the key, what happens.
Big differance from does nothing when key is turned and turns over but will not start.
Still got old gas in it?
03-12-2013, 09:38 PM
#5
MarginallyQualified
pour some seafoam into the gas tank and some down the throat of the carb
03-12-2013, 10:13 PM
#6
If it can't start, you may as well throw it away.
03-12-2013, 10:34 PM
#7
Sorry, I really don't know how to post my thread to certain folders in this forum.
My mover is just works fine and can feel that it needs a little energy to start but I don't know how to adjust it. New Spark Plug, new filter. I think it is no spark when pulling the string.
It is a not too old mower. Yard Machines (by MTD),
5.5 HP, 21 inch cut.
03-12-2013, 10:41 PM
#8
Works fine, but no spark? Hmm.
If there was no spark it would not run.
99% of the time the carberator needs to be removed and rebuilt.
03-13-2013, 03:53 PM
#9
A Little Of Everything
If it will not start at all, after not running for quite awhile, it's almost a guarantee that your gas got old & plugged up your carb.
Usually you can drain out the old gas, and put in new. Remover the air cleaner and give it a shot of starting fluid (you can buy this for about $4 at any auto parts store). It should start, run really rough for a bit, but smooth out.
If you get it running, add a little SeaFoam to the gas. It will clean up the carb.
If you do NOT get it running, let us know & we can go from there.
In the future, before you stop using your mower for the winter, add a little bit of SeaFoam.
The Following User Says Thank You to DrHicks For This Useful Post:
03-16-2013, 02:54 AM
#10
Thanks. I sprayed the Quick Fluid to the Carb. and the engine started running but stopped immediately. The oil or gas or combination of both was spreaded (pushed) out from the exhaust window when engine was running short time. Is it the problem of engine oil leaking or something else. Should replace the engine oil? How to drain it? Where is the leak. How to fix it?
03-20-2013, 07:29 AM
#11
Its the carb from running ethanol gasoline after setting all winter messes carb up
03-20-2013, 10:00 AM
#12
That is not true.
Non-ethanol gas does the same thing.
03-20-2013, 03:19 PM
#13
Master General ReEngineer
Ayuh,... The Carb needs to be removed, 'n Rebuilt....
03-25-2013, 07:08 PM
#14
Roofmaster
Just take it to a mower repair shop, for goodness sakes. The EXHAUST WINDOW???? C'mon man you are over your head!
" A lot of men build things, and a lot of things fall down "
The Following User Says Thank You to jagans For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
