-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   Lawn Mower can't start (http://www.diychatroom.com/f106/lawn-mower-cant-start-174322/)
rliu 03-12-2013 07:02 PM
I have a Yard Machines (by MTD), not used for a while but now it can't start.
I replace the spark plug, air filter and still not solve the problem.
5.5 HP, 21 inch cut
MTD model: 11A-416Q729.
It worked fine before and just long time not using.
What's wrong with it?
Anybody knows? Please help.
oh'mike 03-12-2013 07:31 PM
I moved this to 'small engines /tractors"---Mike----
oh'mike 03-12-2013 07:34 PM
Are you getting spark? Sometimes rust on the flywheel will cause the magnito to malfunction.
That's a bit of work to fix--so see if the spark plug wire is getting juice---
joecaption 03-12-2013 08:19 PM
Need a whole lot more info.
Start from turning the key, what happens.
Big differance from does nothing when key is turned and turns over but will not start.
Still got old gas in it?
TarheelTerp 03-12-2013 08:38 PM
pour some seafoam into the gas tank and some down the throat of the carb
cleveman 03-12-2013 09:13 PM
If it can't start, you may as well throw it away.
rliu 03-12-2013 09:34 PM
My Mover is just need a little more energy
Sorry, I really don't know how to post my thread to certain folders in this forum.
My mover is just works fine and can feel that it needs a little energy to start but I don't know how to adjust it. New Spark Plug, new filter. I think it is no spark when pulling the string.
It is a not too old mower. Yard Machines (by MTD),
5.5 HP, 21 inch cut.
joecaption 03-12-2013 09:41 PM
Works fine, but no spark? Hmm.
If there was no spark it would not run.
99% of the time the carberator needs to be removed and rebuilt.
DrHicks 03-13-2013 02:53 PM
If it will not start at all, after not running for quite awhile, it's almost a guarantee that your gas got old & plugged up your carb.
Usually you can drain out the old gas, and put in new. Remover the air cleaner and give it a shot of starting fluid (you can buy this for about $4 at any auto parts store). It should start, run really rough for a bit, but smooth out.
If you get it running, add a little SeaFoam to the gas. It will clean up the carb.
If you do NOT get it running, let us know & we can go from there.
In the future, before you stop using your mower for the winter, add a little bit of SeaFoam.
rliu 03-16-2013 01:54 AM
Thanks. I sprayed the Quick Fluid to the Carb. and the engine started running but stopped immediately. The oil or gas or combination of both was spreaded (pushed) out from the exhaust window when engine was running short time. Is it the problem of engine oil leaking or something else. Should replace the engine oil? How to drain it? Where is the leak. How to fix it?
William A 03-20-2013 06:29 AM
Its the carb from running ethanol gasoline after setting all winter messes carb up
DrHicks 03-20-2013 09:00 AM
That is not true.
Non-ethanol gas does the same thing.
Bondo 03-20-2013 02:19 PM
Ayuh,... The Carb needs to be removed, 'n Rebuilt....
jagans 03-25-2013 06:08 PM
Just take it to a mower repair shop, for goodness sakes. The EXHAUST WINDOW???? C'mon man you are over your head!
Brad1231 01-22-2015 09:14 AM
I have the same problem with my MTD mover 11A-416Q729. It was used about a month ago and now won't start. Is the spark plug spark suppose to be yellow or a blue? I check the plug for spark and it sparks but it's a yellow color. I'm thinking it's suppose to be a blue colored spark? And does the primer red rubber button suppose to pump enough gas into the carb so I can see it pumping in when I remove the outside cover?
Thanks, Brad
