Honda HRX-217 - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 09-22-2012, 03:00 PM   #1
bubbler's Avatar
Rewards Points: 256
Honda HRX-217
Mowing my lawn today, the mower just sort of "shut down"... It had been running a good 30mins because I had cut over 75% of the yard. The grass wasn't particularly high or anything, I was mowing on a level surface. The throttle was set to "fast" which is how I always mow.
When I tried to re-start it, gave me a VRRroooommmm......stop.
I put the throttle at slowest, restarted and it starts and "idles" for about 20-25 seconds before dying. If I try to increase the throttle while in this state it will immediately die.
- Oil is full and clean
- Air filter is not overly dirty
- Fuel is turned on and flowing into the carb
- Fuel is new this season, fact that it had been running fine for the 30 mins prior would indicate it's not a fuel quality issue
- I get good flow from the tank if I pull the hose from the carb, so it's not a vacuum/flow issue
- I removed the carb, the float bowl is full, but not overflowing
What the heck could be wrong?
BTW this is just another sign that I should buy cheap lawn equipment, because so far season #2 has been an issue for both my expensive mower and expensive weedwacker.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Old 09-22-2012, 04:15 PM   #2
bubbler's Avatar
Rewards Points: 256
I tried my secret all purpose fixing technique...
After a few wacks to the carb and linkages it started and ran normal for another 30 mins until I was done... good enuff
Old 02-04-2013, 11:57 PM   #3
There might be some thing stuck in it that`s way it stopped id..
paulsmith544 is offline   Reply With Quote
Old 02-05-2013, 02:09 AM   #4
Rewards Points: 12,824
Time to pull the carberator apart to clean and rebuild it.
While your at it add a fuel filter to the line.
Honda 3000is portable generator RickDyke Electrical 3 08-26-2014 01:01 PM
Honda Black Max surging??? bajajeff Tractors & Mowers 1 05-30-2012 03:02 PM
Is Honda Generator worth the cost? Dave_T Electrical 2 11-22-2011 10:38 AM
Honda Civic Catalytic Converter cibula11 Automotive Repairs 3 08-27-2008 07:50 AM
1973 Honda 450 Murphy Automotive Repairs 5 07-25-2008 09:58 PM
