-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   Honda HRX-217 (http://www.diychatroom.com/f106/honda-hrx-217-a-157642/)
bubbler 09-22-2012 02:00 PM
Honda HRX-217
Mowing my lawn today, the mower just sort of "shut down"... It had been running a good 30mins because I had cut over 75% of the yard. The grass wasn't particularly high or anything, I was mowing on a level surface. The throttle was set to "fast" which is how I always mow.
When I tried to re-start it, gave me a VRRroooommmm......stop.
I put the throttle at slowest, restarted and it starts and "idles" for about 20-25 seconds before dying. If I try to increase the throttle while in this state it will immediately die.
- Oil is full and clean
- Air filter is not overly dirty
- Fuel is turned on and flowing into the carb
- Fuel is new this season, fact that it had been running fine for the 30 mins prior would indicate it's not a fuel quality issue
- I get good flow from the tank if I pull the hose from the carb, so it's not a vacuum/flow issue
- I removed the carb, the float bowl is full, but not overflowing
What the heck could be wrong?
BTW this is just another sign that I should buy cheap lawn equipment, because so far season #2 has been an issue for both my expensive mower and expensive weedwacker.
bubbler 09-22-2012 03:15 PM
I tried my secret all purpose fixing technique... :hammer:
After a few wacks to the carb and linkages it started and ran normal for another 30 mins until I was done... good enuff :whistling2:
paulsmith544 02-04-2013 10:57 PM
There might be some thing stuck in it that`s way it stopped id..
joecaption 02-05-2013 01:09 AM
Time to pull the carberator apart to clean and rebuild it.
While your at it add a fuel filter to the line.
