Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 05-30-2012, 02:43 PM   #1
Honda Black Max surging???
I have a Honda Black Max 22" mower. I have had this for 2 years with no problems. I went to use the mower today and after starting the motor is surging. I checked the oil, fuel and cleaned the filter. Still surging. To the point the drive mechanism won't really work. The only new thing is I just put a new blade on it. Any ideas?
bajajeff is offline   Reply With Quote
Old 05-30-2012, 03:02 PM   #2
MarginallyQualified
How old is the gasoline you're using?
Drain any old fuel and start with known fresh fuel... and put a new air filter on.
While you have it open hit the carb hard with spray cleaner too
Probably only coincidence.
Make sure the basics are covered most of which is air then fuel quality
and then fuel delivery (relative to air)
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Newbie from Beverly MA and BLACK trim! Rellie25 Introductions 3 11-30-2009 10:24 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 11:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
