Hit A Root With The Mower Lastnight - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-20-2012, 09:52 AM   #1
Rewards Points: 150
Hit a root with the mower lastnight
I've mowed there before and don't remember any root... regardless, it was there now (stupid foreclosed house next door and its overgrown back yard creeping into my yard!!!).
When I hit the root I heard crunch and a eeeerrrrrrrnnnnnnnttttttt!!!! type noise. Tried to start it again but couldn't even pull the starter cord. tipped the mower and found the blade is bent beyond repair and partially off center from where its mounted.
Good thing I finished the front yard first.
I think its possible the the gears could have been stripped. So i wanted to test this before I buy a new blade. Is it ok to start to the mower up without a blade attached?
knotquiteawake is offline   Reply With Quote
Old 07-20-2012, 11:04 PM   #2
Rewards Points: 152
I can't think of anything that would cause damage to the engine by running it without the blade, long enough to see how it runs, but that is assuming that it will start without that weight on the shaft. Before going any farther though, with the spark plug removed, turn it by hand, and see how it feels. Then remove the flywheel, and check the key, to see if it is damaged or broken. After that, I would try starting it, but if it doesn't start at that point, I would invest in a blade, and try it that way.
Old 07-24-2012, 09:24 AM   #3
Rewards Points: 150
I tested it without the blade on and it appeared to start and run. It ran pretty rough but I assume this was because it relies on the inertia of the blade to function properly.
So $14 and a trip to Lowes later I put a new blade on it and it started up just fine. There's a little shudder now and then but before I bought this mower it was treated poorly so thats not entirely unexpected.
Do new blades NEED to be sharpened? Its got a dull edge, seemed to cut grass allright. I have a pretty crappy lawn so I'm not worried about looks or perfect grass.
Old 07-28-2012, 02:13 PM   #4
dogris's Avatar
I've bent crankshafts by hitting objects.
dogris is offline   Reply With Quote
Old 07-28-2012, 03:24 PM   #5
A Little Of Everything
Rewards Points: 1,364
No, you do not sharpen new blades.
That said, I'd suggest you start salting away a little money for a new mower. If this one isn't already toast, it soon will be.
DrHicks is offline   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
Small Yard, Tree Roots....? JayNYOne Landscaping & Lawn Care 6 11-13-2011 06:30 PM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 09:29 AM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
Combo root cellar/chicken coop hykue Building & Construction 2 08-06-2010 05:40 PM
