-   Tractors & Mowers (http://www.diychatroom.com/f106/)
-   -   Help Save this Battery (http://www.diychatroom.com/f106/help-save-battery-176487/)
J. V. 04-07-2013 10:32 AM
I have a 1994 MTD (Lowes) riding mower. 14 HP, 42" cut.
I bought a new battery yesterday and want to make sure everything is working well. The mower starts with ease.
I want to verify the battery is being charged when the mower is running.
I measured the voltage at the battery with the mower off and on.
The voltage difference was minimal.
Is this because the battery is at full charge?
I was looking for a couple more volts while running?
I want to make sure the battery will serve me well and the mower is indeed providing a sufficient charge.
Thanks John
Bondo 04-07-2013 11:49 AM
Ayuh,.... The battery voltage should show 'bout 12 volts sittin', 'n 'bout 13.6 volts with the motor runnin', if it's chargin'...
J. V. 04-07-2013 12:39 PM
I got almost 13 VDC sitting and 13.8 VDC running.
Seems a fully charged new battery would not see a large difference in voltage as the battery is already charged fully.
Lets take this one step further.
I have located the connector that has two wires coming from under the flywheel. These are the wires that charge the battery.
A yellow goes to the line side of the solenoid, (direct shot to positive battery terminal) the white I am not sure where it goes but I can find out.
If I were to disconnect this connector and put a meter across these two charging wires with the engine running, what voltage should I be reading?
This would be a "no battery" reading. Directly from the motors charging output wires.
SeniorSitizen 04-07-2013 12:59 PM
Put a load on the battery for a few seconds by cranking it 10 seconds with the ignition switch off then repeat for another 10 seconds after waiting about a minute . Now check the differential voltage again . You'll probably like that difference better and quit worrying about things that don't need to be worried about .
vsheetz 04-07-2013 02:39 PM
If it when up nearly 1 volt from not running to running, it's likely charging. There is nothing else to make the voltage go up...
SPS-1 04-07-2013 03:23 PM
Thats what I thought too, so I looked it up in Wikipedia, and a charged lead-acid battery will actually make 12.6 v sitting (2.105 volts per cell)
If the voltage while running is more than that, power will flow into the battery and charge it up. I think you are fine.
ddawg16 04-07-2013 05:34 PM
It is charging.....if not, then the run voltage would be the same or slightly less. Your over thinking this....go cut the grass.
jagans 04-12-2013 02:22 PM
Pick up a can of CRC QD contact cleaner, unplug all your electrical connection plugs and spray and wire brush them spray again and plug back in. A lot of crap gets in those plugs over time.
