Has To Be A Way To Adjust - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-26-2013, 04:16 PM   #1
Rewards Points: 588
Has to be a way to adjust
I have a husqvarna push mower and the handle sits below my waist so I have to bend over a lot while I mow and it kills my back. It's at midthigh and I am 6' tall. I don't see a way to adjust it but it just seems crazy like this!
And yes I have a steel cable for a pull cord. Lol
nikeman is offline   Reply With Quote
Old 04-27-2013, 03:56 PM   #2
Rewards Points: 744
Unlikely. you would have to fabricate something.
Seattle2k is offline   Reply With Quote
Old 04-28-2013, 10:34 AM   #3
Rewards Points: 222
you posted all the wrong pics. side view of the lower handle/mower
Fix'n it is offline   Reply With Quote
Old 05-08-2013, 06:23 PM   #4
Looks like the lower handle may have been installed upside down? Hard to see.
cootrp14 is offline   Reply With Quote
Old 05-08-2013, 07:15 PM   #5
Rewards Points: 588
I bought it used but its possible. Ill check out how to remove it next time I mow. The handle literally is below my private parts which kills my back especially on hills.
Old 05-08-2013, 07:16 PM   #6
Rewards Points: 588
Ill take one next time I'm out in the shed.
Old 05-08-2013, 08:14 PM   #7
Roofmaster
Rewards Points: 2,172
why dont you go to parts tree and see how it is supposed to be put together?
Old 05-08-2013, 08:39 PM   #8
Rewards Points: 588
Parts tree?
Old 05-10-2013, 11:26 AM   #9
A Little Of Everything
Rewards Points: 1,364
There's no legitimate adjustment on those handles. They're cheap, and one-dimensional.
Get creative. A guy who connects a steel cable to the pull cord can come up with something!
DrHicks is offline   Reply With Quote
Old 05-10-2013, 12:50 PM   #10
ccarlisle's Avatar
Not necessarily...
You should have two heights; take the handle apart and flip the bottom part over.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 05-10-2013, 08:02 PM   #11
Rewards Points: 588
It's not the length of the handle as much as it is the angle. I just mowed and forgot to take a picture but the metal bracket near the mower part does not adjust and looks welded in place. It seems like that piece would swivel a little to adjust for taller people but it does not appear so.
Old 05-11-2013, 04:58 PM   #12
Too Short? Cut it Again!
Unfortunately, ergonomics never really caught on in the US. Industrial designers are still forced to design to percentiles and those of us taller or those of us shorter, so long as we can work something, do not get stuff designed for us but that is designed for a more common percentile of the population.
Garden equipment and tools are among the worst. At 6'2" I know exactly what you mean and do not get me talking about handles on things like snow shovels. My better half for many, many years was the closest thing to a tree-topper in her family stretching to a staggering 5'2". She also had small, proportionate hands. Nothing in the garden tool arena fit her either.
And you are right, it is usually not just the height on things like mowers, snowblowers, etc., it is those brackets that are welded and set the angle two low for us.
Old 05-11-2013, 06:54 PM   #13
Rewards Points: 192
Most of these have three heights. both the top and bottom sections can be turned over and should have a small arch one way or the other. Make sure both have the arch facing up and should help. Also look at the bottom where it attaches to the deck and you may have multiple slots there.
bcgfdc3 is offline   Reply With Quote
Old 05-12-2013, 07:39 AM   #14
ccarlisle's Avatar
You mean you can't take off the cotter pin and squeeze the handle inwards and flip it over?
Old 05-12-2013, 09:55 PM   #15
Concrete & Masonry
Rewards Points: 530
Get ahold of a 3/4" emt/conduit bender and bend the lower section until they're at the right height...........
jomama45 is offline   Reply With Quote
How do I adjust this old pocket door hardware? ddavissn Windows and Doors 4 06-01-2015 10:02 AM
How to Adjust mixing valve on furnace? maxpower_454 Plumbing 2 10-08-2010 08:59 AM
Multi adjust door hinges on glass doors hansi General DIY Discussions 2 07-20-2010 08:20 AM
Shower door adjust bugme General DIY Discussions 1 12-07-2008 09:27 AM
Adjust low water cutoff? STEPHENWANGEL HVAC 2 02-19-2007 05:23 PM
