Craftsman Mower Won't Fully Engage Gear Or Brake - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-05-2015, 02:50 PM   #1
Rewards Points: 96
Craftsman mower won't fully engage gear or brake
I started up my mower for the first time in a while this morning- the rear left wheel had been removed to repair a tire that fell off the bead.
Seemed to start up just fine, but upon trying to back out of my garage, it barely moved. It almost seems like the darned thing is TRYING to move (it will sort of inch along in the direction if I shake back and forth), but not enough power to move it. Not only that, but depressing the brake/clutch pedal doesn't seem to engage the brake either (my driveway has a slight incline, and pushing it out to there so it started rolling, I wasn't able to stop it with the brake pedal!). Even putting the parking brake into place doesn't seem to hold the mower from being pushed. The pedal seems to fully depress/unpress, but it seems like I can't really get it to move and/or stop.
It was working just fine when I parked it last time, and honestly all I did was take off the wheel to reseat the tire! What did I do??
dishe is offline   Reply With Quote
Old 07-05-2015, 02:56 PM   #2
Rewards Points: 5,220
And the model # is?
Old 07-05-2015, 03:02 PM   #3
Rewards Points: 96
917.256660
But I think I may have stumbled onto the problem... I found this near where I removed the tire:
Could this be the axle key? I must have missed this when I removed the tire- any diagrams for reinstalling?
Old 07-05-2015, 03:28 PM   #4
Rewards Points: 96
Yep. Scratch that, it was exactly what I thought. Found a diagram online that showed this little piece, took the tire back off (stupid e-clip drives me crazy to put back on, but whatever), found the notch, but this little bit on, tire now turns with transmission, brakes stop, everything as it should be!
The Following User Says Thank You to dishe For This Useful Post:
JD367 (07-05-2015)
Old 07-05-2015, 03:37 PM   #5
Rewards Points: 3,988
The reason that doesn't happen more often is that the wheel is rusted to the axle and won't come off. The tire is repaired with wheel still mounted like the big boy tractors.
Do that E-Clip thing 1 more time and Never-Seeze the axle.
SeniorSitizen is offline   Reply With Quote
Old 07-05-2015, 10:27 PM   #6
John
JD367's Avatar
Rewards Points: 202
This is common,when some one removes a wheel. It's how I got my JD so cheap ! I told the PO that it wasn't his trans but he said it was. So,I gave him $300 for it. I was right.
None of the manufacturers put anything on the axle shafts,when they're built,and the dealers don't either .
I make it a point,when someone shows me their new lawn tractor,to tell them this .
It saves headaches,later.
Oh, by the way,....grease the front wheels every other time you mow/use the tractor. It cleans the dirt out of the bushings,and keeps them from wearing out too soon.
JD367 is offline   Reply With Quote
JD mower Kohler CV12.5s-1215 stuck valve? onjtrainee Tractors & Mowers 19 05-18-2015 11:52 AM
Craftsman Self-Propelled Mower Intermittent Power to Right Wheel (Left Wheel is Good) amodoko Tractors & Mowers 4 06-27-2014 03:50 PM
are craftsman 42 in mower decks inter brenda o Landscaping & Lawn Care 1 04-02-2011 05:43 PM
Operator Presence Control bar cable - Craftsman mower SixStrRzr Tools 3 09-29-2010 02:30 PM
craftsman mower problems ccrodeo425 Landscaping & Lawn Care 10 05-06-2009 05:45 PM
